Have I always made a mistake?
pox02
Re: Have I always made a mistake?
no gpu scaling dont add any input lag but choose no scaling u can use display scaling on older driver u have to check it out
Zazie
But if I understand to activate gsync actually I also have to activate vsync from the panel. Quite right?
BlurBoss
No, you don't need to activate V-Sync anywhere to enable G-Sync. You can try G-Sync Pendulum app that allows you to better see the difference. https://www.nvidia.com/coolstuff/demos#!/g-sync
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
Zazie
Ok, but I need to activate this: https://ibb.co/qgGb4NH
ToastyX
I don't think G-SYNC monitors can display non-native resolutions with G-SYNC enabled, so you need to use GPU scaling if you want to use lower resolutions. For the native resolution, it doesn't matter.
pox02
use lower driver
problem fixed
- RealNC
Thought that as well for a long time, but it seems it is possible. Although in a limited (and quite useless) way:ToastyX wrote:I don't think G-SYNC monitors can display non-native resolutions with G-SYNC enabled
viewtopic.php?t=3313
So for most intents and purposes it seems that yes, it's not possible, unless you're OK with a low refresh rate (which defeats the purpose of wanting a lower resolution to gain FPS.)
