Asus XG258 Questionable Overdrive
singleDADAN
Re: Asus XG258 Questionable Overdrive
Post by singleDADAN » 05 Nov 2019, 16:23
Paft wrote:He already said what settings he uses in this thread:
viewtopic.php?f=2&t=5415&p=41696&hilit=settings#p41696
Here's the file if you use 'ASUS DisplayWidget':
(My Gdrive is full so it will have to be mediafire)
http://www.mediafire.com/file/1lpa3lkba ... ty_PT.axml
are those settings he use for gaming ? ddc/ci on or off ? and asus displaywidget not working for me: "Selected monitor not supported"
Paft
Post by Paft » 05 Nov 2019, 16:37
Yes.
I don't think he mentioned DDC/CI. I don't even see those in my monitor options.
Did you download it from the correct page?
https://www.asus.com/us/Monitors/ROG-St ... _Download/
singleDADAN
Post by singleDADAN » 05 Nov 2019, 16:58
Paft wrote:Yes.
system setup->OSD setup
yep i download from official site, tried also diferent versions none works...
quote from some other forum:" make sure to disable ddc/ci add input lag aswell(if you don't need it for anything)"
Paft
Post by Paft » 05 Nov 2019, 17:09
Ah yes, of course. I haven't touched my monitor since I started this thread. I have a terrible memory.
I just noticed DisplayWidget isn't working for me now. "Selected monitor not supported". Strange because I used it the other day to re-apply notty's settings because I saved over it by accident.
I reset the monitor for factory settings and DispalyWidget works again. Go to Advanced Settings>Import
Disable it from starting with Windows because it's buggy for me. It likes to switch profiles on its own. Usually switches to racing.
singleDADAN
Post by singleDADAN » 22 Nov 2019, 05:04
https://prnt.sc/q0i7p9
against vs crt monitor. Clone mode.Both on [email protected]
Post by RealNC » 27 Nov 2019, 00:50
singleDADAN wrote:
22 Nov 2019, 05:04
What happens if you swap the monitors? Clone mode sometimes has lag.
csplayer
Post by csplayer » 11 Oct 2020, 09:32
ogchampion wrote:
09 Jun 2019, 03:23
I'm torn about the XG258Q. It does offer objectively better performance metrics for me in Aim Lab over my 144hz monitors.
Wish I could find an acceptable trade off for the overdrive settings.
Observed in Test UFO with my sample;
OD level 3 gives very obvious colourful shadowy overshoot which I find quite distracting.
OD level 2 solves the overshoot problem but is too weak & introduces heavy 'powdery' trailing.
If only there was an OD 2.5 setting!
There is a way you can kind of customize the overdrive to a more specific value than 0-5 does.
For this you need to open the factory menu by holding the top button when you are starting the monitor, now when you open the OSD you will see a F at the top left which is the factory menu.
There is a option called "OD Strong weak" which is what the overdrive setting changes, i haven't experimented much with this.
However i did find out the corresponding values.
[OSD Menu:Factory menu]
Level 0 = 0
Level 1 = 1
Level 2 = 6
Level 3 = 9
Level 4 = 13
Level 5 = 15
