Ghosting, problem in games, 144hz G sync
karol_
Post by karol_ » 13 Nov 2019, 11:22
Hi! I have a problem with an LG 32GK850G-B monitor. I have it connected through display port with RTX 2080 and running it at 144 hz. On NVIDIA control panel i have g sync turned on and also v sync turned on. When scrolling through web pages i see some ghosting, images are not really sharp. I have also downloaded couple of games recently and even if I have 100+ fps in gears5, outer worlds or dishonored 2 the image seems blurry.
Sample from gears5: https://imgur.com/a/FNp31ed and outer worlds: https://imgur.com/a/QgjoVWf
Re: Ghosting, problem in games, 144hz G sync
Post by RealNC » 21 Nov 2019, 18:20
I'm not seeing anything weird in the second video. In the first video I see motion blur that is generated by the game.
Anyway, isn't this monitor using a VA panel? Some ghosting is to be expected with that, especially on darker colors. (Text for example is usually black and so will have some ghosting.)
elric
Post by elric » 19 Dec 2019, 13:23
I have the same feeling with my 34GK950F which is nano IPS actually.
