Benq xl2430t strobe timings
All newer XBOX consoles supports 120Hz+ & FreeSync. Getting help with getting "Better Than 60Hz" on the XBOX ONE, XBOX Series S, and XBOX Series X, as well as the PlayStation 5.
Curly
Post by Curly » 17 Sep 2019, 14:08
Hi all,
Does anybody know what the best strobe duty/phase settings are for the lowest persistence for 60hz console? I don’t have access to a pc so I’ll do it in the service menu. Any help will be greatly appreciated thanks.
Re: Benq xl2430t strobe timings
Post by Chief Blur Buster » 22 Sep 2019, 18:56
Use horizontally panning 60fps material. Find a game or video that scrolls horizontally, or view www.testufo.com on a smart-TV browser.
Phase -- adjust to preference. Adjust for minimum crosstalk position. For regular 1080p (consoles output VT1125 1080p), phase 0 is usually best.
Duty -- It's a tradeoff between persistence and brigthness. The lower the persistence, the lower the brightness as well. So you will have to find a compromise setting you like.
Curly
Post by Curly » 23 Sep 2019, 17:14
Thanks chief are the duty and phase totals reversed on this monitor?
ArnoldKMB
Post by ArnoldKMB » 15 Nov 2019, 07:58
Thanks, I tried, I did it. :D :D :D
