Kemo, this thread, different page.
If Chief can change the title to 'Asus VG258QR' would be better since everything is discussed here.
viewtopic.php?f=2&t=5018&start=170#p44506
About Asus VG258QR input lag
Re: About Asus VG258QR input lag
This is why I suggested this:
viewtopic.php?f=3&t=5221
This could be the main thread and when someone replies with a question it's possible to specify a new subject, in this case it could be 'settings'.
I apparently also have the same issue now on my replacements only after a day.
https://imgur.com/4DpjcpA
Thank youMatrixQW wrote:Kemo, this thread, different page.
Just to be clear; I should not use FreeSync for QW, right?
Does anyone know what pannel the VG258QR uses?
So i bought the VG258QR
I notice pixel inversion/ Interlace pattern artifacts
I did the Lagom Pixel inversion test, and all cases flicker when i move
When i just stare, no flickering
Is this normal ?
And on https://www.testufo.com/inversion#patte ... bars&ppf=1
The moving picture is full of pixel inversion, i see faint vertical line
Are all TN like this or did i have defective product ?
Is this normal ?
Hello everyone!
So basically i bought the ASUS VG258QR about a month ago, everything was looking fine at first but then i found out that the monitor has ghosting, i tried setting TraceFree from 100 to 80 to 60-40-20-0 and well.. that didn't solve me the problem :\
ELMB is off but when i turn it on i get even much worse ghosting, like literally i barely move my mouse in-game and can see very noticeable ghosting everywhere.
Btw my monitor is plugged in to a GTX 960 and i run 165fps and above, also maked sure that i actually run 165Hz.
I don't know what to do anymore because i also can't return my monitor to the store for a refund anymore so, yeahh..
I am going to get a new gpu soon but god knows if it will solve the ghosting issue :\
Please guys i really need your help, i will much more than appreciate it!
I am returning the VG258QR
When you lower brightness or lower contrast, or both, the vertical gamma shift is too violent
Also pixel inversion/interlace pattern artifacts. On the ips and va, i didnt have it
I didnt notice any ghosting, overshot or smearing
What gpu do you have?Megatone wrote:I am returning the VG258QR
