witega
Post
by witega » 29 Nov 2019, 19:03
addi wrote: ↑28 Nov 2019, 03:35
All my hopes died, that LG will do something about.
Anyway, do you use a custom resolution as stated in the first post ?
If so, what settings are you using ? And are your settings being applied even ?
Yep I'm using the exact settings from the OP.
Sometimes I have to restart the driver a few times (using CRU's "restart.exe") to get it to work properly. I'll run the Heaven benchmark to confirm it's rendering graphics smoothly.
If it's not being applied, then you get a very choppy picture with stuttering every 2 seconds.
And sometimes restarting the driver forces the LG panel out of its blur reduction mode. It's bizarre.
There are still some lingering graphical artifacts in game. I'm getting rid of this monitor for another panel now though.
Hadookaan
Post
by Hadookaan » 16 Dec 2019, 17:06
Screen died, constant white screen, no OSD working, its only a year old, gonna contact LG support for a replacement!
addi
Post
by addi » 19 Dec 2019, 07:10
Hadookaan wrote: ↑16 Dec 2019, 17:06
Good luck with the LG support lmao.
Might aswell contact your dealer first.
Hadookaan
Post
by Hadookaan » 20 Dec 2019, 10:13
Called LG no probs, so far they picked up the display today, let see what happens when I get it back!
ToastyMilky
Post
by ToastyMilky » 27 Dec 2019, 06:06
I've had exactly the same problem. Contacted LG support 1 month ago, they told me to send it to one of their repair center which I did. Still no answer from the support since I've send it.
Hadookaan
Post
by Hadookaan » 28 Dec 2019, 05:38
I did get a message saying they received the monitor at the repair centre, but still nothing since then! I ll wait till sometime in Jan before calling them!
Hadookaan
Post
by Hadookaan » 06 Jan 2020, 07:53
WOW LG messaged repair centre messaged me and said it will take until middle of January, to get the part then god knows how long it will take to get it all repaired, after they get the part, there was a number on the message to call LG which I did, talked to a agent who said I they didn't get any message from me to repair the monitor until after the 23rd Dec,
but they picked it up on the 20th Dec. I said that it was picked up before then, and before I could finish telling there so called agent,
it was before then, she said well we can send it back UN-repaired, what so I can throw is in the trash,
at which point I felt this agent was being a you know what, asked for the manager as I didn't wanna speak this incompetent and totally unprofessional employee, straight away there was no manager! more was said but not going into to much detail, TBC people. (No more buying LG)
addi
Post
by addi » 07 Jan 2020, 05:50
I did not want to be that guy, but i told you
Best luck for you mate.
torabakadora
Post
by torabakadora » 09 Jan 2020, 23:48
Just wanted to chime in. Same white-screen issue after approximately one year (monitor only has a 1 year warranty wtf?) LG 1-800 number was useless with people who rudely direct me to a certified repair center in my area that wont even touch it. I finally found a place to take a look but he claims he cant order the part. If it's the board it looks like it's $21 shipped online and arrives in about 2 weeks. May as well order it and crack it open...
Hadookaan
Post
by Hadookaan » 10 Jan 2020, 19:45
Just had call from the manager today, he said I would get a update on the part and if they don't have it by then then they will give me a option, which is get a new one from the place of purchase, as LG would take longer to get me the same monitor, so lets see what happens! I think there must be an issue with this part going wrong after/before 1 year, that's why they don't sell it in many stores anymore here in the UK just a guess! (I ll try find out what part went wrong, prob the main board what else can go wrong?)
