Am using AmA high, DyAc premium and everything else is on default.
Everything was fine but like 2 weeks ago I started to feel like the monitor is not running fine text is blurry and fuzzy also I feel like DyAc is not working at all and it's way more obvious in games
I went to testufo/crosstalk to check if there is something wrong happening and opened it in full screen mode like for 30 secs to check and after I closed the browser while moving the mouse cursor it feels like the response time went to like 15ms so
I did a reset all from the monitor OSD/ toggle between AmA off and high/ toggle DyAc on and off but nothing changed
I was capturing my TeamViewer id with my mobile camera and I found something Soo weird that the blue reduction lines that keeps moving across the screen (those who are only visible when u check them with a camera. sorry I don't the actual terminology) are running vertically not horizontally as they supposed to be or like I used to see them on my monitor.
So I don't know what should I do now.
