Best 240Hz to buy in early 2020
Re: Best 240Hz to buy in early 2020
XG270 has a dot crosshair with different colors
Nice! Could you take a photo of it?
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
Do you guys think its worth ordering then XL2546 to compare it to the Acer XN253QX. I like this monitor but I am not overwhelmed by it. Many friends of me told me that they love the XL2546 and the DyAC is a killer feature.
No. I have been using XL2546 for a year and had used XN253QP for 1 month. XN253QP blew my XL2546 out of the water in all aspects. The only aspect where XL2546 wins is that it is brighter with DyAc on, than XN253QP with ULMB on. But that aspect is diminished by the fact that XN253QP @144 Hz with ULMB off is smoother (and brighter) than XL2546 @ 240 Hz with DyAc on.
I play a ton of FPS(Halo on PC) I've never tried ULMB before but I see that's what you prefer to play on. I'm ordering the XN253QX today; would you be able to send me a link of how to set up ULMB properly or maybe send me your discord BlurBoss? I'd greatly appreciate it.BlurBoss wrote: ↑09 Jan 2020, 08:03No. I have been using XL2546 for a year and had used XN253QP for 1 month. XN253QP blew my XL2546 out of the water in all aspects. The only aspect where XL2546 wins is that it is brighter with DyAc on, than XN253QP with ULMB on. But that aspect is diminished by the fact that XN253QP @144 Hz with ULMB off is smoother (and brighter) than XL2546 @ 240 Hz with DyAc on.
Forgot to add, there's only a $50 difference between the QP & QX for me, should I just go with the QX?BlurBoss wrote: ↑09 Jan 2020, 08:03No. I have been using XL2546 for a year and had used XN253QP for 1 month. XN253QP blew my XL2546 out of the water in all aspects. The only aspect where XL2546 wins is that it is brighter with DyAc on, than XN253QP with ULMB on. But that aspect is diminished by the fact that XN253QP @144 Hz with ULMB off is smoother (and brighter) than XL2546 @ 240 Hz with DyAc on.
I'm not sure which one is better and I don't have theoretical knowledge to answer this. But I'd be buying XN253QX for me next. To set it up best for you read and do this. viewtopic.php?t=3555 to do it quickly, cap FPS at 141 Hz, enable G-Sync and turn on ULMB only when gaming.Mr___Love wrote: ↑09 Jan 2020, 11:47Forgot to add, there's only a $50 difference between the QP & QX for me, should I just go with the QX?BlurBoss wrote: ↑09 Jan 2020, 08:03No. I have been using XL2546 for a year and had used XN253QP for 1 month. XN253QP blew my XL2546 out of the water in all aspects. The only aspect where XL2546 wins is that it is brighter with DyAc on, than XN253QP with ULMB on. But that aspect is diminished by the fact that XN253QP @144 Hz with ULMB off is smoother (and brighter) than XL2546 @ 240 Hz with DyAc on.
Hello there
I need to chose a screen for competitive multiplayer ONLY (mostly CS:GO), so I'm aiming for 240hz with low input lag.
Should I go for XL2540 or XL2546, or is there new panels that are more interesting still with 240hz and low input lag?
Thanks yall
Thanks yall
Oh and yeah saw about the XG270 but 27 inch is I think too much for my small desktop
I read the whole article but I'm still not sure exactly what settings to change in my Nvidia control panel..what do I use to Cap my Frame Rate? Thanks for the helpBlurBoss wrote: ↑09 Jan 2020, 13:42I'm not sure which one is better and I don't have theoretical knowledge to answer this. But I'd be buying XN253QX for me next. To set it up best for you read and do this. viewtopic.php?t=3555 to do it quickly, cap FPS at 141 Hz, enable G-Sync and turn on ULMB only when gaming.Mr___Love wrote: ↑09 Jan 2020, 11:47Forgot to add, there's only a $50 difference between the QP & QX for me, should I just go with the QX?BlurBoss wrote: ↑09 Jan 2020, 08:03No. I have been using XL2546 for a year and had used XN253QP for 1 month. XN253QP blew my XL2546 out of the water in all aspects. The only aspect where XL2546 wins is that it is brighter with DyAc on, than XN253QP with ULMB on. But that aspect is diminished by the fact that XN253QP @144 Hz with ULMB off is smoother (and brighter) than XL2546 @ 240 Hz with DyAc on.
