OMEN X 25f
- BTRY B 529th FA BN
OMEN X 25f
So I recently turned on Adaptive Sync + G-Sync Compatible + Enable for full screen mode + Vsync ON and my fps are capped at 225fps I have the NVCP limiter set to 237 as well in-game settings at 237. Do I have something set wrong somewhere else? Am I doing something wrong? I thought it should cap at 237. With all of that stuff off it pushes the max fps with the same games.
Re: OMEN X 25f
thats clearly the CSGO ingame limiter. Dont use that one, only use the one in NVCP or use RTSS
XB273QX , Benq 2K 60hz , 8600K @ 5gHZ, 1080Ti , 2x8Gb 3200mhz CL14, Aorus Master Z390
Re: OMEN X 25f
How do I limit the fps in CS:GO? I don't think I've ever set it
Unreal Tournament 4 is locked like that too and it has an ingame fps limiter that works and it's set at 237 but is locked at 225fps
I've noticed when I change V-sync from "On" to "Fast" the fps will hit the NVCP limiter of 237 with both games.
Re: OMEN X 25f
Vsync Always locks u with the screen refresh rate. That means that you will never get more than 240fps with Vsync Activated.
Don't use Vsync for csgo. Generally not good for competitive fps games
Re: OMEN X 25f
I'm wondering what I have set wrong for my fps to be capped at 225 on all games with the settings I mentioned in the OP
Re: OMEN X 25f
The NVCP limiter seems bugged and results in a lower cap than what you've set. I've seen quite a few other people experiencing this.
Re: OMEN X 25f
Just tried raising the FPS limit with V-Sync 'ON' and it didn't effect the maxfps, it's still at 225
Re: OMEN X 25f
Yeah, looks like an nvidia bug.BTRY B 529th FA BN wrote: ↑07 Feb 2020, 15:35Just tried raising the FPS limit with V-Sync 'ON' and it didn't effect the maxfps, it's still at 225
Re: OMEN X 25f
I think you're right.RealNC wrote: ↑09 Feb 2020, 05:04Yeah, looks like an nvidia bug.BTRY B 529th FA BN wrote: ↑07 Feb 2020, 15:35Just tried raising the FPS limit with V-Sync 'ON' and it didn't effect the maxfps, it's still at 225
Also, I tried the latest drivers and overall it seemed to have worse performance; and still have that bug. I went back from 442.19 to 441.87
