MSI Oculux NXG252R or ASUS ROG Swift PG258Q?
spleanned
Post by spleanned » 06 Feb 2020, 01:19
Hi guys, looking to buy a 240hz 24.5'' G-Sync monitor for gaming and not sure which one of these is the better one. The MSI one doesn't have many reviews, and the Asus one is one of the oldest 240hz g-sync monitors, so I am not sure if I should buy it.
Which one would you guys recommend?
dANii
Re: MSI Oculux NXG252R or ASUS ROG Swift PG258Q?
Post by dANii » 16 Feb 2020, 16:20
I'm not sure if the newer 240hz IPS panels don't add alot of ghosting like other IPS panels do. I did not like the PG279Q for example, due to the amount of blur/ghosting.
