benq xl2411p overclocking help
otrtag1
Post by otrtag1 » 01 Jan 2020, 17:38
hello guys i i got the xl2411p by zowie i tried the blur busters method by using 2 monitors but it was not a great thing more than 160 hz half of the screen would be just like shattered glass lol i need help is there any way to overclock this monitor max i can get from nvidia is 149 no more than that goes out of range or is there any way to fix the crap screen after overclocking it higher than 160hz i would appriciate your help :)
Chopper1337
Re: benq xl2411p overclocking help
Post by Chopper1337 » 30 Jan 2020, 17:16
I have the same monitor and am hitting the same limit but with an AMD card. I'm presuming you're using DisplayPort with the cable that came with the monitor, same as I am doing.
I'm not entirely sure as to why but 160hz seems to be a limit of some part of the setup. The AMD drivers don't let me create a custom resolution past 159hz, saying the resolution is not supported by my monitor.
Pixel Clock Patch didn't affect this limit.
Check the specs of your GPU maybe?
My GPU (RX 580) supports DisplayPort 1.4 and the monitor is DP 1.2 so up to 240hz @ 1080p should be possible.
I am starting to believe it could be the cable but more research is needed
BENQ ZOWIE XL2411P 144hz
GTX 1080Ti
Post by Chief Blur Buster » 30 Jan 2020, 22:06
One theory -- it might also be the GPU stubbornly sticking to 8bpc instead of 6bpc -- NVIDIA cards, with custom resolution created, automatically switch to 6bpc during these extreme overclocks.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
another_ash
Post by another_ash » 09 Feb 2020, 07:56
I have a XL2411P and RX 590 and tried overlocking too. I can get past the out of range error easily of course by my display also looks like glitchy 'shattered glass'. I tried switching to 6bpc through AMD display settings and it still does not work. Hoping there's a solution or am I just unlucky with my XL2411P.
another_ash
Post by another_ash » 09 Feb 2020, 08:08
I just fixed the problem by turning AMA off, now I can go to higher frame rates without the problem with my monitor.
Post by Chief Blur Buster » 12 Feb 2020, 22:14
another_ash wrote:
09 Feb 2020, 07:56
It seems like many AMD users are having more difficulty than NVIDIA. Try:
-- Use Instant mode
-- Turn AMA off
-- Try a slightly lower refresh rate, e.g. 200Hz instead of 220Hz.
For me, AMA still works fine without glitching, but this may be monitor-specific.
