What 240hz to use for Rocket League
talo
I'm a top 100 (global 3v3 leaderboard) Rocket League player, I play on a 144hz monitor with scanline sync or it horribly screentears and I'm looking to use a 240hz monitor because I can get constant 250+ fps. So far I've narrowed it down to just the alienware aw2518hl and asus xg248q. I'm not looking to use g-sync as no pro player uses g-sync I just want a monitor good for this game because this game is really fast pace at a pro level.
qtx96
Re: What 240hz to use for Rocket League
Look at the Acer Xf252qx low input lag
- LagBuster
Viewsonic XG270 (because it's Blur Busters Approved).
That or the HP OMEN X 25f if you want the fastest monitor.
snininja
The TUFvg259qm/vg279qm is 280hz so you can run rocket league at the capped 250fps natively
