Help regarding G sync compatible. csgo
MCP
Hello i need some help...
I have a freesync monitor Acer 25 240 hertz.
For csgo.....
Been playing cs from 1.3 version so yeah 2002... So i have skill when it come to CS, it was my main game.
I have this new PC now. So 2070 RTX acter nitro 25 amd 3700x.
In csgo i feel like mouse is not smooth at all, difficulty to aim, it just feel shit to be honnest.
So how should i correctly configure all that stuff ?
In nvidia pannel config atm fps cap at 235 + g sync ON only.
Screen option Freesync is on.
Should i use both g sync + v sync on and dont cap fps ?
I dont really understand all that tbh............. Thanks.
For csgo.....
MCP
Re: Help regarding G sync compatible. csgo
whats the best out of csgo problem i have ? ....
G sync + v sync on no fps cap ? ...
1000WATT
gsync + vsync+ ll on + ingame cap -3fps (237fps)
or
gsync off + vsync off + ll on + no cap
or
There is a possibility that the reason is not in synchronization, but in processor energy-saving modes (BIOS and Windows settings).
MCP
hello there, i use bitsum from process lasso.
But still about my question whats the best ? g sync only + fps cap ?
1000WATT
gsync + vsync+ ll on + ingame cap -3fps = (237fps) For better consistency
gsync off + vsync off + ll on + no cap = for less input lag if you can support 240+ fps.
MCP
Hello.
What do you mean by ll exactly ?
1000WATT
low latency mode
MCP
thank you, i have reaction time set to extreme, should i keep that to normal or off ? low latency mod on + g sync v sync off, i see a differences now to be honnest. finally... !
- RealNC
Depends. If you don't want reverse ghosting, set it to normal. You can test the different settings here:
https://www.testufo.com/ghosting
Most monitors usually provide the best motion quality in their "medium" setting (or the equivalent thereof.) That page allows you to see the differences between the settings, and it's up to you what to use.
MCP
Thanks for your time people.
Id like exactly to know wich settings that have to be off from nvidia control panel and from the screen also.
on/off..
So IMO G sync/Vsync off i get a better feeling thats for sure. From the screen directly now, freesync options should be off in my opinion ??
Here are my settings atm.
Screen options low latency on and reaction time to normal. Freesync off.
Nvidia panel control low latency mod, should i enable it there as well ? Dont think as i have now G sync/v sync off.
on/off..
