ASUS FX505DU (LM156LFGL03) 120hz to 170hz
roodee
Hello there, reporting in. Successfully overclocked this panel to 170 Hz. Although the panel itself quite shitty - only 6 bit with 45% NTSC this is pmuch good result to play FPS kind of games with 1660ti onboard. Works stable without any visual issues.
- 2.jpg (40.31 KiB) Viewed 5265 times
- 1.jpg (235.88 KiB) Viewed 5265 times
Re: ASUS FX505DU (LM156LFGL03) 120hz to 170hz
Hey,
That is a pretty good overclock for a laptop!
And it certainly looks successful from the frameskipping test, too.
