G-Sync at non native resolution
Scriba
Post by Scriba » 20 Mar 2020, 02:21
I'm using in some games a non native resolution (1440 x 1080) with gpu scaling (stretched) on my xn253 for competitive reasons (more vertical FOV).
If I open the monitor Info I see, that G-Sync is not working as soon as I start the game. If I start the same game at native resolution (1920 x 1080) G-Sync is working properly.
Any suggestion how I can solve this? (Input lag shouldn't be much higher).
Thanks for help in advance.
Scriba
Re: G-Sync at non native resolution
Post by Scriba » 20 Mar 2020, 02:49
and for people that don't believe (as I hear that often) that stretching resolution can increase vertical FOV (depends on the game), watch this ingame screenshot.
https://preview.redd.it/itkblyn1jym41.p ... 9972894f92
Scriba
Post by Scriba » 20 Mar 2020, 17:51
Alright I got one step further. If I set the custom resolution in cru G-Sync is working or at least the monitor info shows it.
The thing is when I have heavy FPS drops (from 141 to like 70) there are still some huge stutters. May I should teak the cru settings? I just used the native resolution settings and changed the horizontal pixels.
cru settings.PNG (15.55 KiB) Viewed 7371 times
Scriba
Post by Scriba » 27 Mar 2020, 02:05
Thread can be closed, I'm happy with my custom resolution now (was going over regedit).
