LG 27GK750F-B - 240Hz, 27" 1ms Blur reduction, Freesync
mushi
keep us posted guys.
what part is it exactly? get every detail you can and share for the others please. thanks!
sat5uma
Still worth buying one? I play CS:GO competitively and I looking for a 240hz monitor, with some smoothness better then my VG248QE and I read almost all the thread, was a nice reading, learned so much!!!
Aynway, still worth? despite the firmware not updated/stutter bug? (since can be temporary fixed using CRU)
addi
To be honest, get something else...sat5uma wrote: ↑14 Jan 2020, 14:21Still worth buying one? I play CS:GO competitively and I looking for a 240hz monitor, with some smoothness better then my VG248QE and I read almost all the thread, was a nice reading, learned so much!!!
It is really not worth it.
LG does not care at all. And now a lot of the monitors are just dying...
The customer support is a nightmare.
I'm really not happy with my monitor, i will get something else soon aswell.
Never again LG products.
sat5uma
Sad to hear.addi wrote: ↑15 Jan 2020, 15:25To be honest, get something else...sat5uma wrote: ↑14 Jan 2020, 14:21Still worth buying one? I play CS:GO competitively and I looking for a 240hz monitor, with some smoothness better then my VG248QE and I read almost all the thread, was a nice reading, learned so much!!!
Do you know any other options? with good MBR and low input lag? I prefer TN panels and 240hz.
Unfortunately, I'm from Brazil and the options here are limited.
I saw an AOC 240hz 0.5ms MPRT and 0.5 G2G (specs informations) but TFTCentral said that they are using the new AUO TN 0.5 ms panel but theres no a single review out there.
- Hadookaan
They fixed the monitor and getting it back tomorrow, after just over one month waiting, lets see how it is when I get it! dont hold your breath guys, (didn't find out what part went wrong, probably the main board) 100% sure that in a year it will fail again, if not then I ll be very lucky tbh I ll be happy if it fails I ll get something better then!
I was looking at the 48in oled when it comes out, but I dont want to get anything from LG again!
- Hadookaan
Monitor is back up and running looks like they they changed the LCD panal so maybe it wasn't the ,main board I am no expert but thats what is seems like, I was getting a stuck pixel, with the old/broke panel, which was easily to fix by gently tapping on the pixel with a soft cloth, the panel does seem new, it has a more warm tint to it ie more reddish! compared to my other screen's
Anyway let's see if it can last more than a year, or if it dies just after the warranty runs out!
- RealNC
- k2viper
Wow... they dying as flies, I cant even expect this )
My one still running "fine", meaning now it's not worse when I bought it.
ghostrider94ac
hi @k2viper i used your settings to fix monitor stutters, but when i use strobe crosstalk test on ufo test i experience double o even worse like triple image even on 1180/1182/1304 vt, anyone got same issues? there is a way to fix this cause strobe utility works only on benq if i remember correctly and i just have to run it on normal or freesync mode, is so frustrating cause crosstalk has a very bad impact on my aim in games where i need pin point accuracy
Auroreka7
FUCK
my LG 27GK750F-B just died with the white screen
called LG parts.
I was quoted for this part https://lg.encompass.com/item/11527154/LG/EBU64508601/
$229.03
They don't sell the panel, if that's the issue with the monitor. (possibly out of stock? hard to understand)
called LG parts.
$229.03
