Hi,
I'm new in the forum but I read lot of interesting things here. Now I have a question..
My pc is ryzen 9 3900x, 32Gb ram 3200hz, RX5700XT.
I play 99% on modern warfare and my fps fluctuating between 187 and 260.
Now I want a new montor with quite competitive qualities and good images ( now I use a zowie 2411p)
My choise is between
-Alienware Aw2521HF (ips, 240hz, 1ms, freesync)
-zowie xl2546
-zowie xl2540
-rog xg248q
-rog xg258q
Which one is better for me and why?
Thanks a lot!
Merk
Help choosing competitive monitor 240hz with good image quality
rcarlos243
Re: Help choosing competitive monitor 240hz with good image quality
for 1080P 240Hz
HP Omen X 25F
https://www.rtings.com/monitor/reviews/hp/omen-x-25f
for 1440P 240hz
HP Omen X 27
https://youtu.be/2Ybm_LOKWB4?t=523
both supports freesync and they are the fastest (in terms of response time with little to no overshoot \ ghosting
HP Omen X 25F
for 1440P 240hz
HP Omen X 27
Dude, if you want top tier ips for competive, check this out:
https://www.tftcentral.co.uk/reviews/as ... g279qm.htm
Version of 24 = VG259QM (which I have)
The best IPS monitor I have ever had. Compare to my old TN monitor this one has even fastest response time (1ms is marketing, real is 3.6ms anyway AVG, because if you want lowest then this one get 0.9ms then but the real is 3.6ms which is the fastest of all IPS) + low input lag + 280hz (u should use 240hz anyway).
Just check the review
