GSYNC lowest input lag i can get for competitive
PeppexITA
Post by PeppexITA » 23 Apr 2020, 14:58
Guys, i want to play games competitively but games like apex legends without gsync is not smooth, what's the best setting of gsync for the lowest input lag? It's maybe gsync+141fpslimit? Do i need ultra low latency too? Im so confused, help me thank you
PeppexITA
Post by PeppexITA » 23 Apr 2020, 15:19
Best input lag gsync settings for 144hz? I wanna play competitive
Re: GSYNC lowest input lag i can get for competitive
Post by Chief Blur Buster » 23 Apr 2020, 15:29
PeppexITA wrote:
23 Apr 2020, 14:58
If you don't want tearing, 141fps at 144Hz is your best bet. Enabling NULL at default settings is a good idea, although VSYNC ON / NULL doesn't activate often during 141fps cap. Caps are imperfect, some frames are 1/130sec and some frames are 1/150sec, to average the cap, and only the "fast" frame times gets the alternate sync technology treatment (e.g. VSYNC ON + NULL).
The bottom line -- keep it easy -- as long as you cap a few fps below Hz, the sync settings you configure doesn't apply very often because the fallback sync technologies only triggers at frame rates equaling or exceeding Hz.
Be noted,
- 141fps cap at 240Hz VRR is lower-lag because of lower scan-out latency.
- 237fps cap at 240Hz is even better.
So, in the long term, you should consider an upgrade to 240Hz (or even 280 Hz or 360 Hz), if you plan to play lots of competitive CS:GO.
CS:GO wants to run at ultra-high frame rates (300fps+) so there are significant competitive improvements getting a 240Hz+ G-SYNC monitor for CS:GO if you love to play with G-SYNC.
PeppexITA
Post by PeppexITA » 23 Apr 2020, 15:42
Chief Blur Buster wrote:
23 Apr 2020, 15:29
PeppexITA wrote:
23 Apr 2020, 14:58
Be noted,
I have a gtx 1070, i7 8700k and 16gb ram, for apex legends, to make it run smooth and with minimum input lag, the best option is gsync +141 fps limit? do i need null too for make it even better?
Post by Chief Blur Buster » 23 Apr 2020, 16:06
PeppexITA wrote:
23 Apr 2020, 15:42
NULL helps more if you're not capping.
Use an in-game cap and the sync settings (other than G-SYNC) will usually not matter since NULL would typically only activate for frame rates equalling max Hz.
If you want even lower lag, 300fps VSYNC OFF can be helpful, as an advantage of frame rates above refresh rates. However, if you hate tearing, capped G-SYNC is one of the lowest lag alternative.
PeppexITA
Post by PeppexITA » 23 Apr 2020, 16:11
23 Apr 2020, 16:06
PeppexITA wrote:
23 Apr 2020, 15:42
the problem is the fps goes from 200 to 100 on apex on low settings, and i don't see it smooth, what happens if i gsync+141fps limit+null ultra?
Post by Chief Blur Buster » 23 Apr 2020, 16:15
PeppexITA wrote:
23 Apr 2020, 16:11
Use NULL at default settings (not Ultra) if you use that with G-SYNC.
NULL lag-savings is simply a backup to G-SYNC lag-savings.
NULL only activates when the cap is exceeded.
Which means NULL makes no difference when there's a good cap below Hz. NULL on/off makes no difference if frametimes are always within refresh rate range. Enabling NULL at the same time as G-SYNC is fine, it generally doesn't make much difference when the cap is well below Hz.
For uncapped NULL (non-GSYNC) versus capped G-SYNC (NULL on/off), the capped G-SYNC is typically better (lower lag) for in-game frame rate caps.
141fps at 144Hz is the best way to smooth things out without tearing or excess latency.
From worst to best, for most games
(Laggiest) - G-SYNC + VSYNC ON only + no cap
(Less lag) - G-SYNC + VSYNC ON + NULL without cap
(Even less) - G-SYNC + in-game framerate cap below Hz (regardless of setting VSYNC ON/OFF/NULL)
They can overlap somewhat. Make sure to disable VSYNC in your video games (even if you use VSYNC ON in NVIDIA Control Panel), this will allow the game to run at their lowest-lag behaviour with G-SYNC.
jorim can add more info to this.
PeppexITA
Post by PeppexITA » 23 Apr 2020, 16:43
23 Apr 2020, 16:15
PeppexITA wrote:
23 Apr 2020, 16:11
so the best setting for apex is gsync+141fps limit+null on? Im so bad in those things sorry (fps limiter with rivatuner or game limiter from origin for apex?)
Post by jorimt » 23 Apr 2020, 17:09
PeppexITA wrote:
23 Apr 2020, 16:43
For lowest lag no-tear G-SYNC configuration in Apex:
G-SYNC enabled + NVCP V-SYNC "On" + Low Latency Mode "On" + in-game V-SYNC "Disabled" + in-game "Display Mode" set to "Full Screen" under "Video" options + minimum 141 FPS in-game limit @144Hz (Origin > My Game Library > Apex Legends > cog icon > Game Properties > Advanced Launch Options > input +FPS_max 141 without quotes in "Command Line Options," save).
For lowest possible input lag, set +FPS_max number to a framerate your system can sustain 99% of the time without maxing out your GPU usage. This is optional, but will even further reduce the pre-rendered frames queue over Low Latency Mode "On," but will also obviously lower your possible average framerate.
PeppexITA
Post by PeppexITA » 23 Apr 2020, 17:34
jorimt wrote:
23 Apr 2020, 17:09
PeppexITA wrote:
23 Apr 2020, 16:43
what if i dont care about tearing and i disable vsync? I dont even notice tearing, i only want to be smooth
