BenQ XL2411P can't measure refresh rate at 144hz
PlayTekken
I bought an XL2411P so that I could use blur reduction mode anywhere from 60hz to 144hz, and am trying to get low-lag VSYNC to work. I'm having trouble using the refresh rate test at https://www.testufo.com/refreshrate, though. When I go to display properties and set my monitor to 144hz, the refresh reate test fails and tells me VSYNC can't start. If I set it to 120hz it works fine. Does anyone know what could be causing this? Thanks in advance!
Re: BenQ XL2411P can't measure refresh rate at 144hz
This is a browser issue, not a monitor issue.
Try unplugging your 60Hz monitors. Multimonitor will give you refresh rate interference.
Try switching between FireFox and Chrome.
(Moved this to the TestUFO forum)
