Hello Guys,
iam new here and need your help, with my new Viewsonic XG270 Elite.
i tried many ways to fix this with no results.
the native resolution with 1920x1080p with max of 120Hz is in the Nvidia Control Panel on HD resolutions
when i change to PC resolution with 1920x1080p with 240Hz ( No Native ) my screen is not smooth and clear.
all drivers uptodate, my gpu is the evga gtx 1080 ti ftw 3 elite gaming black edition.
using windows 10 1909
here another issue, my monitor settings of HZ Limitier does not match the Nvidia Settings
Native resolution is under HD resolutions
- Screen2.png (104.04 KiB) Viewed 3448 times
Re: Native resolution is under HD resolutions
You should just leave the Hertz limiter at 240hz. Viewsonic's implementation of it is buggy and results in frame skipping
https://www.youtube.com/watch?v=OC0WBwKOTMk
If you want to play at 240Hz, put both the Hertz limited in OSD and the setting in NVCP at 240hz
it was just a example pictures
240Hz in Monitor Settings and NVCP dont change the problem.
Native Resolution is still under HD-Resolution.
PC-RESOLUTION 1920x1080p with 240Hz is just awful, screen is not smooth and clear.
btw. i dont have the XG2402
