Incorrect native resolution(TV resolution) instead of PC XG2402
ko4
Re: Incorrect native resolution(TV resolution) instead of PC XG2402
Post by ko4 » 30 Apr 2020, 14:11
tuvok_ wrote:
30 Apr 2020, 12:53
wow i got the same issue with the ViewSonic XG270 Elite
look:
when i change to PC-RESOLUTION screen is not smooth and clear.
I Just have 1920x1080p NOT Native with 240, 144 and 100Hz.
Any Recommendation for a high quality DP Cable?
Not sure which ones you can get in germany, but make sure it is VESA certified
I doubt that will fix the problem though. I'm using a good cable as well and tried multiple
I think it might just be a bug in nvidia's driver. I watched a couple of AW2518hf reviews and TV resolutions also appear in nvidia control panel
If you really want to get rid of it, you can delete the TV resolutions with CRU.
tuvok_
Post by tuvok_ » 30 Apr 2020, 14:42
[/quote]
[/quote]
Any Amazon Link, maybe they have someone for europe?
Ty I try Custom Resolution with CRU and its much better then before.
But this cant be the solution for a Expensive Monitor for FHD.
