I hope everyone is keeping safe at these times. I am having some flickering issues with this monitor, especially when I play Destiny 2 it flickers a lot in the character menu (where you equip weapons and armor etc.) Its driving me a bit nuts to be honest. So what I have figured out so far is that by disabling freesync on the monitor side eliminates this issue completely. I mean that defeats the whole purpose of the monitor
So far what I have done to try to resolve the issue is changing D.P cables, updated all my drivers, updated my bios. Did a DDU as well and reinstalled the driver. I'm completely fresh out of ideas. I tried to change the Freesync range as well its currently set to 48-144hz but no luck to get it to stay as the monitor would go completely blank after I change the range. The ranges that I tried for was 30, 35, 40-144hz.
To add as well I have noticed that the fps would drop very quickly on the monitor side, To explain I use the fps limiter in destiny to set it to 141fps and activate v-sync in the nvcp. When monitoring the fps counter on the monitor it would read 144fps even though I capped the frame rate to 141fps in destiny. The game fps would read 141fps. When I open the character menu the fps in game would drop a little or fluctuate a bit but it will hold a steady frame, while the monitors fps reader would be going crazy from 144-90-60-48 back to 144fps very quickly, at this time the monitor would be flickering like almost a florescent light that is shorting out lol. I know this might not be the correct place to post this but I'm trying anywhere to get some advice.
Any Assistance would be greatly appreciated
My Specs:
Amd Ryzen 5 3600
x570 Aorus Elite Wifi
16Gbs Corsair Vengeance pro rbg 3200mhz
Evga 2070 super xc ultra
1tb nvme
