Great looking forward to that rly hard time deciding right, gonna be my first 240hz monitor.RLCScontender wrote: ↑20 May 2020, 21:06Will post the aw2521hf response times in a bit and how it performs relative to ALL fast IPS monitor(that $2000 LG ultrawide wont be included). Ima add the viewsonic xg270qg, 27gl850, rog strix xg279q relative to the 240hz IPS monitors.
First feeling told me to go with the MSI Optix MAG251RX but it is not available for the next 2-3 months as it seems.
Now i am stuck between the VG259qm and the AW2521HF.
And right now i am more leaning to the AW2521HF. Never used backlight strobing, so i won't miss it.
But i am still not 100% sure.
Got a 5700 xt so g sync won't be used. Staying above 240hz in the games i play competetive won't be a problem.RLCScontender wrote: ↑20 May 2020, 21:06yup, u have to turn on adaptive sync if the fps is below 240hz, otherwise u will see stuttering, tearing, and judders. Also, make sure u turn on v sync if u want the scaler to synchronize to ur gpu correctly so g sync compatibility will be serviceable.
My fPS is always above 240hz so i never use any form of adaptive sync.
That's the issue with freesync monitors, it doesnt have variable overdrive so anything that is below the refresh rate the performance will go down and inverse ghosting start to creep in. That is the side effect of non native g sync panels.
Another thing, if u are getting under 200 fps, i suggest u get a stronger GPU or calibrate your display for performance.(example. lowering resolution ). Bcuz if ur not getting 240hz fps, then the refresh rate is counter productive
And turning on freesync for maybe some AAA title won't be a dealbreaker i think, just want good colors for the AAA titles.
Anyways thank you for your response.
