Just pulled the trigger on the XG270!
Ryno24
Re: Just pulled the trigger on the XG270!
Post by Ryno24 » 26 May 2020, 14:38
Chief Blur Buster wrote:
25 May 2020, 09:32
Excellent. Yes, that is what G-SYNC and FreeSync is for, it helps reduces stutter from frame rates mismatching refreshrate.
Also, if you use a very scrolling-intensive game, test 120Hz + PureXP + VSYNC ON + NVIDIA Ultra Low Latency
How do I get it to 120hz? All I see is 100hz and 144hz.
Post by Chief Blur Buster » 26 May 2020, 19:27
Ryno24 wrote:
26 May 2020, 14:38
There are two separate 1920x1080 sections in NVIDIA Control Panel -- scroll until you see the other 1920x1080 setting, and you will see 120Hz listed there.
Ryno24
Post by Ryno24 » 26 May 2020, 21:37
Got it! Thank you!
Post by Chief Blur Buster » 26 May 2020, 21:53
Ryno24 wrote:
26 May 2020, 21:37
Got it! Thank you!
You are welcome!
ballzley
Post by ballzley » 27 May 2020, 23:49
Ryno24 wrote:
21 May 2020, 18:22
Don't worry Chief I used your link to purchase! :mrgreen:
Where's the link??
Ryno24
Post by Ryno24 » 28 May 2020, 07:06
ballzley wrote:
27 May 2020, 23:49
Ryno24 wrote:
21 May 2020, 18:22
Where's the link??
Go to blurbusters.com, go to monitor list, then best monitors and it will be the 1st one then click on the blue name.
ballzley
Post by ballzley » 29 May 2020, 00:38
Ryno24 wrote:
28 May 2020, 07:06
ballzley wrote:
27 May 2020, 23:49
Ryno24 wrote:
21 May 2020, 18:22
Where's the link??
Ty ty
Swizz
Post by Swizz » 29 May 2020, 11:26
Congrats. I own the XG270QG and love it. However my brother just got the XG270 and is having screen turning black just like in this vid
https://youtu.be/0JX3DdyqSNQ
Cant seem to figure out what to do. Have you had any issues like this?
Post by Chief Blur Buster » 29 May 2020, 12:09
Swizz wrote:
29 May 2020, 11:26
I posted in the other thread you made:
Cause #1:
A bad/loose DisplayPort cable or port is also a secondary cause of screen going randomly black. Try a different DisplayPort port, and also a different DisplayPort cable.
Cause #2
Have the monitor upgraded its firmware yet via Viewsonic Elite Display Controller?
A new monitor firmware is out already, which fixes some known issues.
1. Connect USB3 cable (included with monitor) to the USB hub built into monitor
2. Install www.viewsonic.com/elite/display-controller/
3. When prompted to upgrade firmware, proceed
Cause #3
Refresh rate range bug in drivers if this ONLY happens during VRR. Using ToastyX to edit refresh rate range to use 55Hz-240Hz instead of 48Hz-240Hz can help reduce the low-framerate flickering problem. But you said this problem happens even without VRR?
