Locked
Max_hz
Post by Max_hz » 29 May 2020, 06:41
@ bleach
Yes that is annoying, had you not seen that dead sub-pixel before or did it arise later? luckily you get a refund! Are you buying a VG259QM again or has your attention shifted to another model?
Indeed for an RMA 1 dead sub pixel is not enough
kofman13
Post by kofman13 » 29 May 2020, 14:32
man can you make a TN tier list too? (after the new zowie XL2546S comes out :))
bleach
Post by bleach » 29 May 2020, 14:42
Max_hz wrote: ↑
29 May 2020, 06:41
@ bleach
VG259QM is out of stock here, but VG279QM is not. I ordered a VG279QM a few hours ago. I didn't notice the dead subpixel until like 2-3 days after receiving the screen.
ee energy is eternal
sanoff
Post by sanoff » 29 May 2020, 17:31
Maybe instead of arguing which monitor will be better maybe voted together for MSI MAG251RX on RTINGS.com and then for the next ones that interest us to learn more and from professionalists?
kofman13
Post by kofman13 » 29 May 2020, 23:11
sanoff wrote: ↑
29 May 2020, 17:31
i read this comment 5 times and i still dont understand what ur trying to say
sk1p
Post by sk1p » 30 May 2020, 02:02
kofman13 wrote: ↑
29 May 2020, 23:11
sanoff wrote: ↑
29 May 2020, 17:31
Probably, he wanted review of MSI MAG251RX from rtings as it has authoritative opinion, but I believe to RLCScontender measurements and think he did great job! He deserve a donation, but sorry I am poor Russlan :D
Max_hz
Post by Max_hz » 30 May 2020, 04:18
bleach wrote: ↑
29 May 2020, 14:42
Max_hz wrote: ↑
29 May 2020, 06:41
@ bleach
Ok thanks for sharing, I wish you better luck with his big brother
Max_hz
Post by Max_hz » 30 May 2020, 04:19
sanoff wrote: ↑
29 May 2020, 17:31
Nice entry to this friendly informative and helpful forum!
Slazyel
Re: 04/18/2020. The IPS 240hz monitor tier list.(I've measured/tried the all) and my honest explanation why.
Post by Slazyel » 30 May 2020, 12:16
ItwasLuck wrote: ↑
26 May 2020, 02:33
RLCScontender wrote: ↑
22 May 2020, 18:03
input lag results for anyone curious on which has the lowest overall input lag. You would be surprised. The nitro xv273x is probably the lowest input lag of all the monitors right now(not named OLED)
the 25" predator has excellent input lag too. Man, i too was shocked. yes, when i played rocket league, you might think that 0.4 input lag difference is miniscule, but in a dexterity heavy game like rocket league, it adds up. one button press is 0.4, but if you press buttons in your controller 200 times a minute, this will determine whether you get a perfect blindsided shot on goal or a WHIFF that will send your car flyign open for a counter attack.
for competitive gaming, the acer clones have the lowest input lag but the worst g2g averages.*at least that's what i measured*
I am definitely keeping my Acer XB253Q GX. It is an outstanding panel, definitely not like that MSI you got from the lottery (Oh, do I envy you!!!). But regardless for gaming, I am having such a blast with this monitor. I did the human benchmark test and I am getting sub 200ms results so I believe the results you posted are definitely not that accurate to the individual panels.
You mention that 0.4ms input lag is huge, I definitely agree. I came from a Samsung SVA panel (144HZ) and I have to say, everything just seems way more SNAPPY (even at the same 120HZ). I am tracking targets (using VRB @120HZ) so well that my HS accuracy went up 2 folds!
For a real-world test, I loaded up CoD and picked a gun I never use so that I can see instantly how accurate I am. After 11 games, I am getting a headshot accuracy of 55%.
Keep in mind, my next best accuracy (with the gun I use the most) is only 24%. I'd say that is a major difference.
If anyone is curious, on CoD Warzone my headshot accuracy is 24% with an MP5 and 55% with an MP7. I believe this clear advantage has to do with how easy it is to track a moving target. The fluidity allows me to take shots that I normally do not take. And I felt this even when sniping with an HDR.
You mentioned earlier that G2G is more important than input lag and I have to disagree entirely. For gaming, input lag means everything. As long as the G2G is low enough that motion blur isn't noticeable, input lag should be the decisive factor in determining the best panel for gaming. I am willing to sacrifice 1ms of G2G if I have 0% overshoot. I do wish the Acer panels had better overdrive settings. The only option you can ever use is Normal.
In terms of quality, I believe the Acer Predator is much better especially compared to the ASUS 280HZ panel. My first panel (and the one I kept) has amazing black uniformity and imperceivable IPS glow in normal low-light conditions. I will make an update later for color accuracy.
I am curious about VRB however. I am stuck at 120HZ and it is impossible to go up to 144HZ. I was wondering if only the Nitro panel allows VRB @144HZ.
If anyone is in the know, please tell me why the Acer panels are so much better than the rest when it comes to input lag! TFT Central did a great review of the Acer Nitro XV273 and they believe it to have 0 signal processing. The only lag from the panel is simply the pixel response time element.
I also was wondering why you refer to them as Acer clones when the Nitro version has slightly lower input lag in your tests. I honestly believe that they all use the same panel. The 27" panel could just be slightly better actually. The Acer's just seem best for gaming. The colors on mine are actually quite good and I am picking up an X-Rite to calibrate mine. I did some DCI-P3 tests and I definitely see a difference so my panel is well above the sRGB spectrum. Now how close I can get to DCI-P3 will just be the icing on the cake.
I just have to say, guys, I LOVE this panel. I honestly have never seen such a drastic improvement in my gaming performance from any SINGLE upgrade. I have upgraded graphics cards, went from air to water cooling over a decade ago, replaced all fans with GT Typhoons (if noise had any impact on concentration lol), upgraded my mouse from a Zowie FK2 to an FM UL2, upgraded my headphones to the Audeze LCD-2C with a SMSL SU-8 DAC / THX 789 amp setup. And while each of those changes helped me slightly, nothing compares to upgrading to this panel. The advantage that I have in-game is just so perceivable, I am lost for words.
Hi, can you tell me wich settings are you using? What options did you put on or off? What calibration you are using?
I have the same monitor and it's incredible. It's WAY better than my previous 1440p XB271HU. But i dont find anywhere a calibration for it. I'm using it at factory default settings minus the sharpening effect that was on.
vlkfree
Post by vlkfree » 30 May 2020, 18:47
@Slayzel turn off sharpening effect
like i said, this acer is the better price/quality monitor ever
when i tried FPS games, that was like with my TN monitor
i think i did a mistake : i refunded my monitor
i am waiting for the xl2546s (preorder....)
Locked
