Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
ptuga
- schizobeyondpills
Anonymous768119
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Wow, that is huge difference. Obviously something is wrong with my rig but I don't have enough knowledge to solve it.
- dervu
Ryzen 2600 @ 4.0, Corsair Vengenance RGB Pro 3200 CL16:
- latency.png (57.39 KiB) Viewed 12886 times
ptuga
4000Mhz 15-15-15-35.schizobeyondpills wrote: ↑10 Jun 2020, 16:13
Tool didnt finish measuring latency, there's still pending measurements on L2-L2 H/Miss at the bottom, please test again with browser/discord etc all closed.
how do i make an image into a url
Test closes after l2-l2.
Anonymous768119
So what I realized now, doesn't matter what frequency and timings I set, it's not affecting latency significantly and first steps are oscillating around 500us and then dropping to ~85.
Shyzo
Now that´s an interesting topic.
Would any of you guys mind to explain to me how I can install this program for windows?
I don´t really get the explanation on their page:
1000WATT
ask schizobeyondpills, Brainlet. I think you are sitting in the same chair.
Brainlet
Run CMD as admin, navigate to the folder and then type
, optionally with with the avx instruction setmlc.exe
mlc.exe -z
Starting point for beginners: PC Optimization Hub
Shyzo
Thanks. I also did a run
Ryzen 3600, 3200Mhz Ram 16-18-18-36
Tomahawk B450 Max
Tomahawk B450 Max
