I am trying to figure out why the BENQ Blur Reduction & Strobe Utility is no longer working. I have a XL2720Z monitor with V2 firmware. I used to work, but now it doesn't. I reinstalled the BBR Utility, but that doesn't work. I tried changing resolutions and refresh rates, turned off and on the monitor and rebooted my computer...nothing seems to work. I even tried toggling on and off some of the monitor menu settings such as DDC/CI but to no avail.
The BBR Utility opens up fine and recognizes a supported monitor, but then you adjust any of the settings (override, persistence, and crosstalk) it does nothing. It seems that the monitor is stuck on the previous settings I had which were Persistence at 2.0ms and 0 (far left) Crosstalk. Unchecking and checking the "override "doesn't affect the image either. Other than playing with a few different VT settings, nothing else that I am aware of as changed on my system.
Any ideas on how to get the BBR Utility working again?
[fixed] Benq Blur Reduction Utility No Longer Working
Rekt
Okay, well I figured it out. I must had the OSD locked. To unlock the OSD, you have to press and hold one of the buttons on the side until it says it's unlocked (10 secs). Once that happens, BBR Utility works again. I guess the OSD option in the Menu only locks the OSD, it doesn't toggle it on and off.
I wonder if this should be put under the FAQ just in case someone else has this issue.
Re: [fixed] Benq Blur Reduction Utility No Longer Working
Good points!
Need to make sure:
-- Must be outside of service menu
-- Must not be in burn-in mode (pressing button brings up burn-in menu)
-- Must not have OSD locked
Need to make sure:
