What is the BenQ XL2546 Panel model?
wanjo
Post by wanjo » 15 Jul 2020, 13:30
Hi everyone!
I am looking for a replacement BenQ XL2546 panel but I cannot seem to find the exact panel number I've checked on https://www.displayspecifications.com/en/model/f24cb92, and it does not seem to show you the panel model.
I found out that the BenQ Xl2540 uses the M250HTN01.3 panel.
But I can't find anything on the XL2546 Panel. The only difference between those 2 monitors is the brightness (400 vs 320). Would using the M250HTN01.3 work on the XL2546?
Re: What is the BenQ XL2546 Panel model?
Post by RealNC » 15 Jul 2020, 15:07
Moved to more appropriate section.
jorrell279
Post by jorrell279 » 16 Jun 2021, 09:25
Hi there! Did you manage to find which auo panel model the zowie xl2546 uses? I'm in the same boat as you as I can't seem to find anything on the Internet about it. Any help would be great, thanks.
axaro1
Post by axaro1 » 16 Jun 2021, 11:22
jorrell279 wrote:
16 Jun 2021, 09:25
The XL2546 uses the Q250HTN00 A000.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
jorrell279
Post by jorrell279 » 15 Jul 2021, 20:23
thanks a lot man
