I hope you can help me guys
My problem is that GSYNC stops working after a couple of hours in cod warzone. I need to reboot my pc otherwise its not working anymore.
But its not specific to this game.
I had this issue a couple of years ago. Same behaviour. I played Battlefield 5 and sometimes out of nowhere the gsync indicator disappeared and it started to stutter so gsync wasn't active anymore. The only solution I had was to make a fresh clean install of windows 10 and the problem was solved.
But for now it's different because I just bought a new PC and the only thing I did is Windows installed, battlenet installed and msi afterburner to be sure my system is working fine without any issues. No other apps except all drivers for the system and of course the programs I need for headset, mouse and keyboard etc.
I set all the settings for GSYNC exactly like the description from blur busters.
Any ideas why GSYNC stops working and what I can do except clean win 10 installation? Because I don't think that helps anymore.
My system :
Ryzen 3770x
Asus2080super
Asus prime x570 pro
Win10 with latest updates /drivers
Asus pg278qe @165hz
Thanks guys,
Boby
