NVIDIA Low Latency Mode - On or Off for less Input lag?
Defox
Greetings!
Based on the tests, when GPU is not loaded at 99%, for some reason the input lag at the "Ultra" value is little increased compared to "Off". Will there be an increase input lag in the same situation when set to "On" compared to Off? I have not found any comparison between "On" and "Off"
What do I need to choose (on or off) for the lowest latency with a constantly not GPU bounded?
UPD:
In a recent video of Battle(non)sense about "NVIDIA Reflex", I noticed that it recommends setting the low latency mode to "Off". Why not "On"? If I am correctly aware, then the "On" value forces the maximum number of prepared frames to 1, which will give us confidence that the game will not prepare more than 1 frame.
Are there any explanations and assumptions why he recommends installing it "Off"?
UPD:
Defox
Re: NVIDIA Low Latency Mode - On or Off for less Input lag?
I searched deeper and found this post.in non-G-SYNC scenarios, according to Nvidia, "Ultra" LLM has a "just-in-time" frame delivery mechanism, so in non-GPU-bound situations, it may occasionally time delivery of a frame too late, missing a fixed refresh window, causing the previous frame to repeat once over, instead of the next frame showing. If this even happens every few seconds, each of these repeat frame occurrences could cause a minor average input lag increase over LLM "On" or "Off" in non-GPU-bound situations.
So the "On" value as well as "Off" does not increase the latency in the case of no GPU bounded compared to "Ultra", right?
There was one more question. In the case of a GPU bound, does "On" reduce input lag as well as "Ultra", or does "Ultrа" do it better? What should I use with the GPU bound for the minimum input lag?
TTT
Leave it set to 'On' universally and forget about it.
On is the same as max pre-rendered frames '1', off is let the game decide.
Setting it to Ultra is supposed to reduce latency when you have your game uncapped and you are GPU bound and still only achieving 60-100fps.
Battlenonsense did a vid though and showed you can decrease latency even more by not having it on and capping your GPU usage below max.
- MaxTendency
Somewhat true, but this behavior is game dependent and doesn't apply universally. On games like ow capping fps can reduce input delay but thats not the same with every game. Hardware unboxed did a newer video on this testing a wide variety of games and there seems to be no one stop solution to weather you should cap your fps or not.
Click on the picture to take you to the full video.
- jorimt
This is true, but...MaxTendency wrote: ↑01 Aug 2020, 09:04but this behavior is game dependent and doesn't apply universally.
If that's the same video I think it is (saw it when it was released), it's confusing, doesn't lay out its methodology explicitly enough, and is thus wildly inconclusive.MaxTendency wrote: ↑01 Aug 2020, 09:04Hardware unboxed did a newer video on this testing a wide variety of games and there seems to be no one stop solution to weather you should cap your fps or not.
At one point I wasn't even sure they knew what they were testing for any more, and in some instances they may have been conflating it with other factors, including counting in sheer framerate input lag (like in the screenshot you embedded, the differences of which were directly due to an increase in frametime proportionate to the avg FPS drop, not the LLM setting used).
Any setting that manipulates the pre-rendered frames queue has the most effect in reducing input lag when the GPU is saturated, and is preventing the CPU from handing over the newest information to complete render.
In non-GPU-bound situations, LLM is more likely to affect frame pacing than input lag. And in GPU-bound situations, it's more likely to first affect average framerate before it affects input lag.
LLM is unnecessarily obsessed over, as it honestly has the least potential impact on input lag out of GPU-side user configurable settings. You're looking at a frame or so of input lag reduction in specific GPU-bound situations, at best.
If these settings were any more impactful, AMD and Nvidia would continually market the crap out of them, yet they don't.
Basically, if you use G-SYNC, it's safe to leave LLM set to "On." If you use fixed refresh, it's safe to leave LLM to "On," or try "Ultra" per game (may or may not induce more stutter depending on the system/game combo).
MPRF settings (and even HAGS, for that matter, which FYI, is ultimately related to the pre-rendered frames queue) will really have the most impact on weaker or non-gaming systems. So if your system is at all capable for gaming, said settings are going to be a case of diminishing returns more than not.
Bottom-line is, you don't even want be in a performance position where your system has to resort to relying on LLM in the first place, and if you want to ensure the lowest possible input lag from a GPU standpoint, prevent it from maxing out, LLM or no LLM.
That's really it.
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
TTT
That example isn't right though, its not GPU bound anyway. Nvidia themselves said Ultra is made for a GPU bound scenario.MaxTendency wrote: ↑01 Aug 2020, 09:04Somewhat true, but this behavior is game dependent and doesn't apply universally. On games like ow capping fps can reduce input delay but thats not the same with every game. Hardware unboxed did a newer video on this testing a wide variety of games and there seems to be no one stop solution to weather you should cap your fps or not.
The reason capping comes into it is to stop you from hitting 100% GPU, not just capping to random frames.
- jorimt
Yup, that particular graph shows differences in input lag due to frametime, not LLM. At points, they really seemed to lose track of what they were trying to originally test for.
TTT
Don't get why people keep posting this same question, the answer is probably in half the first page threads!
- jorimt
search.php?author_id=2920&sr=posts
Defox
There was one more question.jorimt wrote: ↑01 Aug 2020, 09:35Bottom-line is, you don't even want be in a performance position where your system has to resort to relying on LLM in the first place, and if you want to ensure the lowest possible input lag from a GPU standpoint, prevent it from maxing out, LLM or no LLM.
That's really it.
To get lower input latency in "Low Latency Mode = Ultra" - we need to limit in-game FPS below 138 (in the case of a 144 Hz monitor).
But. If there is no in-game limiter. Does it make sense to limit FPS using the nvidia control panel (as we know it increase input lag)? Will this decrease the input lag or, on the contrary, increase it?
