What settings for Asus VG259QM 240hz vs 160~fps
Sacraficemygoat
Re: What settings for Asus VG259QM 240hz vs 160~fps
Post by Sacraficemygoat » 06 Jul 2020, 20:51
axaro1 wrote:
04 Jul 2020, 03:22
Sacraficemygoat wrote:
03 Jul 2020, 23:11
Thanks for the suggestions, unfortunately i'm still experiencing stuttering. It may just be my graphics card. Not really sure.
I noticed another odd bug, sometimes when I alt tab from a game (mainly Destiny 2) back to windows, freesync or something messes up and Windows gets stuttering as well (monitor shows around 86Hz, when usually it's at 240Hz.) I have to turn the monitor off and back on for it to register as 240Hz.
Considering doing another clean install of Windows and see if it fixes it, or possibly install 1909 instead of 2004..
sometime it happens to me aswell in Overwatch, it seems to be the only game affected, idk if that's an issue with 2004 or a monitor issue, sometime pressing Alt-Enter two times (to turn a fullscreen game to window mode and to fullscreen again) seems to fix this issue.
Interesting. I'm going to clean install 1909 and see if it fixes the issues I've been having. W10 2004 has a lot of bugs still and I'm fairly certain most of the issues im experiencing are because of 2004.
Sacraficemygoat
Post by Sacraficemygoat » 07 Jul 2020, 00:40
axaro1 wrote:
04 Jul 2020, 06:57
milojr21 wrote:
04 Jul 2020, 04:17
I noticed if you have Full Screen Optimizations off it introduces this delayed alt+tab.
I agree, FSO off seems kinda bugged with 2004
How do you toggle FSO on/off in 2004? I don't see the option anywhere, just VRR.
axaro1
Post by axaro1 » 07 Jul 2020, 05:21
07 Jul 2020, 00:40
axaro1 wrote:
04 Jul 2020, 06:57
milojr21 wrote:
04 Jul 2020, 04:17
I just disable it for each game, right click on the .exe file > Property > Compatibility > Disable full screen optimization
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
EastEndBear
Post by EastEndBear » 07 Jul 2020, 13:36
Having to go into the OSD customised settings to change profiles is a real pain. Is there a quicker way?
CyCl0ne
Post by CyCl0ne » 14 Jul 2020, 11:15
What is the minimum (0%) brightness in cd/m2?
zelva
Post by zelva » 24 Aug 2020, 17:15
guys, do you see 280hz in windows adapter settings in vg259qm or only 240hz? When I turn on overclock mode at 280hz i can only see 240hz? But in application softmccs i can see 1920*1080@280hz? I can play valorant only at 240hz, it forces maximum refresh rate always even if you have it in windows on 144hz for example.
Post by Chief Blur Buster » 24 Aug 2020, 19:51
zelva wrote:
24 Aug 2020, 17:15
Which screen do you only see 240Hz in?
If in NVIDIA Control Panel, scroll down, sometimes there's multiple groups of refresh rates for a specific resolution. One set under "Ultra HD, HD, SD" section (where 60Hz is) and one under "PC" section (where 144 Hz is), for the 1080p resolution.
It's confusing sometimes.
Blur Busters even has an article, "Oh No, I’m At The Wrong Refresh Rate: How To Change Refresh Rate" for those people stuck at 60Hz...
zelva
Post by zelva » 25 Aug 2020, 04:42
What do you mean which screen? I have AMD R9 290x. I can only get 240hz, even tho I overclock it to 280hz/270hz with OSD. I tryed reinstalling drivers, pluging in/out display port, the cable is new with monitor. The thing is I can still see it when I change from 240/270/280, it creates new resolution in CRU, but it is not showing it windows display adapter nor working ingame. I tryed creating custom res (copy pasted CRU) but it is not allowing me to create new resolution in AMD drivers. https://prnt.sc/u5gvt0
Max_hz
Post by Max_hz » 25 Aug 2020, 10:35
Maybe the pixel clock of the AMD R9 290x doesn't go high enough for above 240hz
zelva
Post by zelva » 25 Aug 2020, 11:09
Maybe it is yes, I already tryed Amd pixel patcher 1.48 its the same.
