If you have more info, don't hesitate to share it!
UPDATE: (copied from comment below vid)
Code: Select all
We got a SLEW OF NEWS from BenQ themselves!
https://zowie.benq.com/en/xl-k-series.html
Basically, the stand changes are supposedly there, not as a cost saving measure, but instead a space saving one.
Both the new XL2546K and XL2411K will come with the new stand.
The 2546K is still 240hz, and the 2411K is a (hopefully budget) 144hz monitor with DyAc and an S-switch.
Idk whether the 2411K uses a newer panel than the 2411P (I think) it replaces, but if it does, it should also have better colors than it's predecessor, along with finally getting the beloved S-switch and DyAc.
They also redesigned the OSD, judging from the pictures, and the OSD buttons have been moved to the back of the monitor, with the addition of a joystick.
Now you can also easily share your monitor settings via software!
No word on the XL2546K-B yet.UPDATE 2:
Introduction vid by Benq, link copied from Conan's comment.
