I'm noob, please help
I'll play a little bit of everything, so the fps can vary from 50/60 to 110/120.
So, if I understand correctly, given the difference in fps compared to the refresh rate, if I don't want tearing, I need VRR.
But a tv like the q90t has no gsync module, so no variable overdrive.
Correct?
At what frequency does the static overdrive of a monitor / tv work? usually at maximum refresh?
So if the overdrive runs at 120hz and I play a game at 70/80fps in VRR, do I risk ghosting effects?
maybe I said a lot of bullshit, I don't know
