Yes I do have similar experience with that 20-30min time frame, when playing with something like a power conditioner, at first the mouse felt good for about 30min, but I knew if I waited a bit it would become floaty again.Palacko wrote: ↑23 Aug 2020, 12:43I guess the biggest problem at my pc is also that the mouse feels floaty. I got 3 new pcs and they all worked fine for about 20-30-50Mins and after that always this weird mous feeling. Fees like the mouse is on ice or something like that. Was it nearly the same for you? I think i noticed it everywhere also in bios very laggy or on desktop also weird. And glad to see that people like you could fix itmy problem started since i installed a metall house next to mine and we also put electricity in it. but i dont really know what we damaged there. Under this house there are also internet cables and also electric. I hope i can fix it too
With the extra details you shared, it sounds very likely that you do have a grounding problem. Please consult with an electrician to help make sure things are wired correctly. Over here we use small electric water heaters in the shower, which I believe is the biggest hazard/danger with respect to wiring. These types of devices should be on their own ground rod if possible to eliminate the chance of bad wiring elsewhere causing a fatal shock.
If you have a multimeter, you can test some things. With AC volts, probing the hot(line) and neutral should read 120V or 220-240V depending on where you live. Hot to ground should still read the same 120-240V, if 0V that means ground not connected. Neutral to ground should ideally read 0-1V. If there is high voltage, like over 30-70V, go through the house and unplug things and recheck the voltage. Bad surge/extension cords can cause this and should be replaced.
Now if you did find high voltages in neutral to ground, that means that the neutral to ground isn't bonded at your main panel, where the power comes in from outside and connects to the circuit breakers and needs to be fixed by connecting the two. Again, please study a bit more and consult a electrician. Check these voltages in the new metal house too, this thing sounds like it should have some special consideration for its grounding as well. Try to follow the rule of thumbs mentioned earlier for installing the rods. Good luck and be cafeful!
