Measurements were made by numerous websites many years ago when the digital connections first came out, including AnandTech, and it was found to be minor (e.g. 1ms or 2ms).flood wrote:Are there actual measurements of this? or is it something related to the HDMI/DVI/DisplayPort protocols?Chief Blur Buster wrote:VGA is the lowest lag, while HDMI/DVI/DisplayPort has a bit more.
I suppose it varies depending on the graphics card and monitor...
Is Bodnar input lag tester accurate?
Re: Is Bodnar input lag tester accurate?
flood
it would be interesting to try that again on modern hardware.
The only thing I could find is
http://www.anandtech.com/show/3754/a-ne ... w-review/8
This makes sense but there could be some overhead inherent in DVI. Regardless it's not a big deal and I avoid vga on lcd screens simply to not have to adjust phase.In addition, using the VGA input on any LCD is bound to add additional lag, as this is definitely a hardware scaler operation to go from analog to digital signaling, compared to the entirely digital DVI datapath.
