Chief recommended I go with the Z series to replace my current triple monitor set up for my race rig so I ordered one, the 2411Z to evaluate it before purchasing the other two.
I need to be very certain of a few things before buying the next two and calling this a 'done deal, game over'.
I have ONE EVGA GTX780 (03G-P4-2781-KR). It has the following outputs:
- Dual Link DVI-I
- Dual Link DVI-D
- DisplayPort
- Useless HMDI lol
I opted for the 2411Z instead of the 2420Z as a non-wireless remote switch and it's side plug are not practical. I use a stand, not a desk.
Questions:
1- Will the outputs on my single 780 provide connections for 3 120hz monitors? I'm actually confused about the DVI-i vs DVI-d -they are both Dual Link if that helps. I'm not sure if Chief caught my reference to having a single card.
I assume that in the future I will probably need more horsepower to run the more demanding race sims @120hz, however, I currently get well over 240fps running iRacing at 5760x1080 on my current 60hz monitors.
2- Will I need another DP to DVI adapter? I currently use an "active" DP to DVI adapter with one of my monitors however, after further reading it has me believing I will need something like an Accell B087B-007B instead of the one I am currently using ( something similar to the the Accell Adapter SKU: B087B-005B). Mine cost about $30, the other cost about $95.
Both called "active" so you can understand the confusion there
3- Would it be a bad idea to purchase 1 2420z and 2 2411z's just to avoid the adapter? Just curious, never mixed monitors before.
4- I am wondering if opting to purchase 3 2411z's that have no DP's would in some way well, bite me in the butt in the future. Is there something I should be considering here? A serious reason to go for the 2420z's instead perhaps?
I am still pouring thru this forum and learning. I forget half of what I've read so I starting taking notes on things I think will be important. There seems to be a lot of tweaks and tricks you guys are using on monitors and I am a complete noob when it comes to that so.. baby steps. lol If there is a step by step to tweaking a BenQ z monitor I'd love a link. (so far I've tried the Strobe utility -excellent! and did the 1350 tweak - although I don't quite understand it yet)
Thanks for your help,
Bailey
