Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Digika
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Post by Digika » 05 Nov 2020, 07:20
First reviews are out, not seeing any latency test tho
Niko
Post by Niko » 05 Nov 2020, 19:57
YES, even now with Zen3 they have higher Core to Core latency
Conan
Post by Conan » 06 Nov 2020, 01:35
Niko wrote:
05 Nov 2020, 19:57
mind if you show some links for that?
MaxTendency
Post by MaxTendency » 06 Nov 2020, 21:50
Conan wrote:
06 Nov 2020, 01:35
Inter-ccd communication is still very slow. But honestly, the core to core latency within the ccd looks quite nice, so one ccd processors like the 5800x might not be too bad. Memory latency is still pretty bad compared to intel, lowest I saw was 48ns (aida).
Sources are all linked into the pictures.
Conan
Post by Conan » 06 Nov 2020, 23:27
MaxTendency wrote:
06 Nov 2020, 21:50
Thank you very much :!:
Gonna throw myself on reading :geek:
Digika
Post by Digika » 07 Nov 2020, 02:11
MaxTendency wrote:
06 Nov 2020, 21:50
Conan wrote:
06 Nov 2020, 01:35
Yeah, Intel always was good on some genius trickery to minimize memory latency, especially when they increase cache size.
Here is hoping ZEN 4 will address it in 2021 since it should be new platform
dervu
Post by dervu » 07 Nov 2020, 06:53
Ryzen 5600X having ~63ns in AIDA64 with 3200 with Corsair CMW16GX4M2C3200C16 (16-18-18-36).
Measuring in mlc (even with newer 3.9) version I get worse result than on old 2600 Ryzen. Maybe it is not good tool to measure it on Ryzen.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor (source removed) 8-)
ffs_
Post by ffs_ » 07 Nov 2020, 10:16
Have you tried 3800 mhz or better (Zen 3 should be able to reach 4000 mhz)?
dervu
Post by dervu » 07 Nov 2020, 16:39
Seems like Try it option doesn't let me use my memory with anything more then 3200 (XMP).
schizobeyondpills
Post by schizobeyondpills » 07 Nov 2020, 21:59
dervu wrote:
07 Nov 2020, 06:53
can you post 5600X MLC screenshot for research info and aida screenshot aswell to compare. ty
