I see, and does top and bottom lag matter at all (last question) if the differences is 2-3msjorimt wrote: ↑23 Nov 2020, 20:33The difference you're seeing between the two models probably has to do with how each handle the scanout rate conversion at lower than 240Hz refresh rates.
If your device was capable of measuring at 240Hz, it probably wouldn't show as much of a difference between them.
Does having 60FPS using VRR have lower input lag than 60hz? Confused*
nursejoy
Re: Does having 60FPS using VRR have lower input lag than 60hz? Confused*
- jorimt
If you're playing at 60Hz, potentially where updates at the very top or bottom of the screen are concerned.
But again, if you're playing at 240Hz, or 60 FPS 240Hz VRR, then what you're device is reading at 60Hz likely isn't an issue at max native Hz on either monitor, as no scanout rate conversion is then taking place.
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
nursejoy
I understand. Thank you so much for all the answers and help!jorimt wrote: ↑23 Nov 2020, 21:07If you're playing at 60Hz, potentially where updates at the very top or bottom of the screen are concerned.
- jorimt
No worries
