HUGE Fix at Input Lag!!!!
Re: HUGE Fix at Input Lag!!!!
Thanks ffs
Not sure that's what he meant?! There is no alternative "flip" option under that setting that I can see. At the end he said use Disallowed together with ULL off...also not sure why that would be relevant when disabling FRL.
Has anyone tried the preferred refresh rate ff0 thingy? Can it even make a difference when you run at fixed refresh with no sync?
i want share 2 nips one for gsync and other no vsync monitors
bypass dwm in nvidia driver
make sure all those 3 on 1
Gsync monitors change framelimiter v3 to ur hz
240hz 236 fps 180hz 176 fps 144hz 138fps
no vsync nip use 0x4 which is flip for more snappy movement in game u can change to v2off + disallowed for lower input but i like more smooth game movement with non vsync
gsync=http://www.mediafire.com/file/fkoiutr32 ... c.nip/file
nonvsync=http://www.mediafire.com/file/l8nkpt4gs ... c.nip/file
Thanks for sharing pox!
How did you find those settings and how did you confirm it's bypassing dwm?
u can see the driver override the dwm which dont let it run in fullscreen games and its works monitors xg258q aw2518hf 27GK750F-B pg248q xg240r lg w2363d-pf xb270hu XL2546 XL2546K NXG252R
Ahh good catch, I didn't notice that!
But how do you know it actually changes anything? Dwm is still doing it's thing from what I can see(fullscreen optimization still works etc.)
because im in win 7 thats why its feels a lot better win 10 its impossible to bypass dwm without two monitors
Okok, yeah I'm on win10...dwm sucks. Thanks again for the tweaks, good stuff!
No dwm no fso thats mean every game run on full screen exclusive mouse more snappy on win 7 less services gsync run better then win 10 u want more?
