Cyberpunk 2077 -- Mouse movement issues/observations
howiec
Re: Cyberpunk 2077 -- Mouse movement issues/observations
Post by howiec » 18 Dec 2020, 10:21
kiry4 wrote: ↑
16 Dec 2020, 19:52
I have Ryzen 5 5600X and RTX 3070 and Asus VG259QM. I believe 280hz not good idea for Cyberpunk (or I'm wrong) so I will use 244hz. Which setting should I use to get smooth experience? Adaptive Sync + ELMB and Gsync+Vsync off. Or what you can advice?
For CP2077, some of this depends on your preference. But if your primary goal is smoothness NOT lowest input lag and/or motion clarity, then I'd say (like Chief listed):
Use the maximum refresh rate (280Hz?)
Gsync ON
NVCP Vsync ON
In-game Vsync OFF
In-game FPS CAP = monitor refresh rate minus 3
ELMB is your preference (assuming the VG259QM has a good implementation of it)
I also highly recommend using DLSS Quality in this game if you want good performance while using RT, and less edge aliasing/shimmering/flickering.
TN_fun
Post by TN_fun » 18 Dec 2020, 17:49
I alone feel that the game has a motion blur that cannot be turned off? I turned off reflections, I even turned off TAA through the tweaker, but there is still blur.
It definitely doesn't work.
60-70 fps, 144Hz. Native frequency or gsync doesn't matter. I don't see this blur in other games.
drjackmann
Post by drjackmann » 18 Dec 2020, 20:53
i think the game has an inherent 'graininess' to it. after disabling film grain, motion blur, and those other related settings, you can try creating a game profile in nvidia control panel and enabling the sharpening setting.
howiec
Post by howiec » 19 Dec 2020, 04:39
TN_fun wrote: ↑
18 Dec 2020, 17:49
Yes, as I mentioned previously, I experience the same regardless of various settings states. For obvious reasons, enabling a bunch of settings that increases post-processing and using DLSS worsens the blur.
Post by jorimt » 19 Dec 2020, 13:37
howiec wrote: ↑
19 Dec 2020, 04:39
TN_fun wrote: ↑
18 Dec 2020, 17:49
I haven't played the game (not interested in an extended beta test myself; may pick it up in a few months), but that sounds like the engine relies on some temporal rendering/blending, regardless of user configurable settings.
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
howiec
Post by howiec » 19 Dec 2020, 13:53
jorimt wrote: ↑
19 Dec 2020, 13:37
Yeah, and maybe I'm too used to high monitor refresh + high game FPS. Could be a combo.
Post by jorimt » 19 Dec 2020, 13:59
howiec wrote: ↑
19 Dec 2020, 13:53
Definitely; direct contrast is a kick in the pants.
depatere
Post by depatere » 19 Dec 2020, 14:33
As someone who is super sensitive to input lag, I too feel like the mouse feels kinda off ingame. Feels like there is some smoothing on it, defnitely not like raw input.
Also, does anyone else get big frametime hitches in game for time to time? Maybe due to SSD loading? I dont know..
sharknice
Post by sharknice » 19 Dec 2020, 21:42
Setting sensitivity to 1 seems like it helps with the diagonal issue. It still feels weird though.
Post by Chief Blur Buster » 19 Dec 2020, 22:34
sharknice wrote: ↑
19 Dec 2020, 21:42
Yes, it definitely does. I have tried my prototype Razer mouse at 1000Hz, 2000Hz, 4000Hz, and 8000Hz, and none of it really helps fix the diagonal issue except setting sensitivity to 1. Raising DPI to 12800dpi helps somewhat, and keeping poll rate lower, helps somewhat -- it seems like Cyberpunk doesn't do a good job of maintaining mousepolltime:photontime.
I complain about mouse problems in the HD Mouse API proposal, but Cyberpunk 2077 needs a lot of mouse optimization, IMHO.
Fun game though, and CD PROJEKT RED has their hands full fixing other bigger bugs, but once that's out of the way, I'd like Cyberpunk 2077 to seriously properly optimize the mouse for more fun solo mouse gameplay.
Some hard-working CD PROJEKT RED developers (when their management allows them time to do so) should read the The Amazon Human Visible Feats of Milliseconds as well as HOWTO: Please Future Proof your Game Engine (Even if stuck on 60Hz Monitor).
When milliseconds become a significant percent of a refresh cycle at high-Hz, imperfections show that didn't show at 60 Hz.
The game engine's ability to keep gametime:photontime consistent to submilliseconds levels needs some major optimization in the mouse department.
Power users of high-refresh-rate lore, are often powerful by word-of-mouth. Bad word-of-mouth can hurt game sales, so I would consider this a medium-priority item that should be done after the game-breaking stuff. I have helped developers fix problems before, see CloudPunk ChangeLog crediting me of Blur Busters, another cyberpunk game developer I helped -- this changelog credits me for de-jankifying this game to future-proofed levels.
