Freesync Monitor 240hz IPS 1Ms
TonyNeenz
I have the Lenovo Legion Y25-25. It has AMD Freesync Premium, now is that similar to GSYNC? in the OSD i have freesync and HDR turned off because i read it causes input lag ? I honestly cant tell the difference when freesync is on or off. But i have been experiencing delays while playing Cold War and Apex Legends. It just doesnt feel snappy or crisp. In NVCP, i have vsync as "use default 3D setting" triple buffer off, prerendered frames to 1, and everything else default. Any advice? I would like to game with that snappy crisp feeling like on my old BenQ TN panel.
Rufussle
Re: Freesync Monitor 240hz IPS 1Ms
Turn Vsync ON in NVCP, OFF in games, Set a frame limit to 3fps less than your monitors max. Input lag from going freesync/gsync on is negligable. HDR causes more input lag than variable refresh rate can. Here is an example from a random monitor test scores taking from rtings
INPUT LAG
Native Resolution
1.6 ms
Native Resolution @ 60Hz
9.2 ms
Variable Refresh Rate
2.0 ms
Variable Refresh Rate @ 60Hz
11.9 ms
10 Bit HDR
4.1 ms
Black Frame Insertion (BFI)
5.5 ms
INPUT LAG
Native Resolution
1.6 ms
9.2 ms
2.0 ms
11.9 ms
10 Bit HDR
4.1 ms
5.5 ms
