Official Asus ROG Swift 360Hz PG259QN Owners Thread
Q83Ia7ta
Which one 360 is better by motion clarity - less response time (less blurring) and less overdrive artifacts? By Asus or Alienware?
StareX
diakou
I have heard 10x more complaints for the PG259Q's (some QN's) than the alienware aw2521H.
I'm pretty sure you can get the AW2521H for cheaper often as well due to the $669-710 deals from time to time on dell's site.
The complaints might also just be because more people got the PG's as figuring out what 360 is in stock or is available was hard.
MSI was supposed to release a while ago, they just went silent. The Acer is out, but I haven't heard many opinions of anyone using it or having it yet.
- BTRY B 529th FA BN
Geekdll
They use the same panel. RTings reviewed both of them and there are pretty much identical in their testing. The Asus has a better stand from what I seen over the Alienware. MSI and Acer are releasing there 350hz monitors soon but I believe they all use the same panel the differences will be minuscule if any at all panel wise. Also some models might come with the Reflex Latency Analyzer feature. The aesthetics and stands will be different depending on the brand you go with and of course price.
Monitors: Asus ROG Swift 360Hz PG259QNR - BenQ Zowie XL2546K
StareX
Geekdll wrote: ↑06 Jan 2021, 22:50They use the same panel. RTings reviewed both of them and there are pretty much identical in their testing. The Asus has a better stand from what I seen over the Alienware. MSI and Acer are releasing there 350hz monitors soon but I believe they all use the same panel the differences will be minuscule if any at all panel wise. Also some models might come with the Reflex Latency Analyzer feature. The aesthetics and stands will be different depending on the brand you go with and of course price.
Though, what do you think of this monitor? is it worth getting?
Im not gonna use their stand cuz I got a monitor arm
dANii
I currently play Valorant and CSGO. My specs are: 9900KS RTX2080 Super.PMaestro wrote: ↑25 Dec 2020, 20:31Hey,
What kind of games do you play if you don't mind me asking?
I want to make the purchase, but Dyac+ is just really good, I had the omen x25f before the 2546k
I play a lot of FPS games and considering this purchase.
What specs are your PC also?
Thanks in advance
Lucasre5
in response time the alienwere wins. In clarity of movement and ghost they are basically very similar. ELMB on alienwere is better than on asus and asus doesn't even have sharpness control, which is terrible
Q83Ia7ta
I've started to trust less RTINGS since they wrote AW2521H is 25" and PG259QN is 24" monitor, while both of them are 24.5".Geekdll wrote: ↑06 Jan 2021, 22:50They use the same panel. RTings reviewed both of them and there are pretty much identical in their testing. The Asus has a better stand from what I seen over the Alienware. MSI and Acer are releasing there 350hz monitors soon but I believe they all use the same panel the differences will be minuscule if any at all panel wise. Also some models might come with the Reflex Latency Analyzer feature. The aesthetics and stands will be different depending on the brand you go with and of course price.
I know they are using same panel but quality of overdrive can differ a lot and result is different. I guess I will wait for some cheaper non g-sync models like this 390hz version from Acer - Acer Nitro XV252QF https://twitter.com/TFTCentral/status/1 ... 3066063872
Stevie66
Keep releasing these weird hz, just give us the 480hz already heh
