My Monitor has V5 Firmware i flashed myself years ago with the Mstar adapter.
I bought what is supposed to be a good VESA certified cable and it looks very nice indeed : https://www.amazon.com/KabelDirekt-Disp ... 87&sr=8-18
At 1st i had some issues : no display at all. Used DDU to clean the drivers, reinstalled them and finally succeeded.
Since i never had any issue at boot, or when i use it.
But my problem is this one: everytime i turn off the monitor AND the display go on sleep (windows settings), i always have the "no signal" message when i push the monitor power button. The only way to get a display is to unplug and replug the DP cable.
If i move my mouse to wake before i power on the monitor : "no signal" => needs to unplug/replug the DP cable
If i power on the monitor then wake moving my mouse, typing a key whatever : sometimes it works
So it's like the monitor loses the connection with the GPU.
My GPU is a GTX1080. I flashed it with the Nvidia displayport firmware (https://www.nvidia.com/en-us/drivers/nv ... pdate-x64/) which is meant to fix issues with DP 1.3/1.4 . Anyways XL2720Z is DP 1.2
I tried pretty everything i could think about :
-disabled every sleep mode on the mainboard. Still S0/S1 is active only.
-disabled hdmi autoswitch on the benq monitormenu
-tried to change various settings on the service menu such as "auto power"
-disabled hdmi autoswitch on monitor settings
=> Now i'm clueless.
If it's an issue with my GTX1080, it's not really a problem because i can go back on DVI until i get a new card with only DP to get 60+Hz, but if it's a monitor issue, not matter the GPU i hook on, i really need to fix it.
Any clue ? Thanks
