I tested the "Benfei HDMI to DisplayPort Adapter" at 120HZ on the ZOWIE XL2411P 144Hz. The adapter is necessary for this model because the HDMI chip has a max throughput of 60HZ @ 1080p.
Will using this adapter to translate the signal reduce the benefit of 120HZ (when the goal is lowest input delay)? - Is it possible to measure/test delay when using this adapter?
The adapter isn't a long term solution...i'd appreciate any feedback.
Monitor: https://zowie.benq.com/en/product/monit ... 2411p.html
Adapter: https://amazon.com/gp/product/B0752D33PJ/
Model Number 000152black
[Editor note -- Linkified your links as they are approved]
HDMI to DisplayPort
Fall
HDMI to DisplayPort
Re: HDMI to DisplayPort (??) | XL2411P @ 120HZ
A DisplayPort-to-HDMI conversion and vice-versa, can be relatively unbuffered (just line buffer / packet conversion). In theory, this adaptor would only add an insignificant latency.
Fall
Thank you for your explanation.Chief Blur Buster wrote: ↑26 Jan 2021, 04:17A DisplayPort-to-HDMI conversion and vice-versa, can be relatively unbuffered (just line buffer / packet conversion). In theory, this adaptor would only add an insignificant latency.
