braavosraider
Post by braavosraider » 26 Jan 2021, 14:52
Hey guys will VG259QM have problem if I only can reach 100-150fps with 280hz + OD120 + VRR ON/OFF + NO ELMB/BFI?
I also read somewhere that in 'ancient' hardware limited game it also become unplayable with this monitor... is it true?
Really appreciate any answer because I'm gonna buy one soon.. Thanks!
axaro1
Post by axaro1 » 26 Jan 2021, 18:14
braavosraider wrote:
26 Jan 2021, 14:52
280hz OD60 VRR(Adaptive Sync) ON, ELMB OFF is what you are looking for.
Preferably with a 275 fps cap and Vsync enabled.
26 Jan 2021, 14:52
no
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
braavosraider
Post by braavosraider » 26 Jan 2021, 22:28
axaro1 wrote:
26 Jan 2021, 18:14
26 Jan 2021, 14:52
26 Jan 2021, 14:52
no
I see.. so do you mean the lower the fps, the lower the OD level? what about VG279QM is it the same? (lower fps = lower OD level)?
and what about freesync instead of adaptive sync ? I read somewhere adaptive sync have higher input lag than freesync CMIIW
many thanks! :)
DukeDice929
Post by DukeDice929 » 27 Jan 2021, 02:17
Found one more firmware (MCM105) inconsistency.
Toggling "Blue Light Filter" [ON(any)->OFF] resets "User Mode" color settings to RGB: 100-100-100.
My bad English :0
Max_hz
Post by Max_hz » 27 Jan 2021, 05:17
Confirmed, I'm on firmware MCM104
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 27 Jan 2021, 08:27
Max_hz
Post by Max_hz » 27 Jan 2021, 11:14
BTRY B 529th FA BN wrote:
27 Jan 2021, 08:27
How do I update my firmware? I'm on 103
You don't until Asus release a (new) firmware download link on the site, I've my doubts on that.
https://www.asus.com/Displays-Desktops/ ... _Download/
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 27 Jan 2021, 11:37
16nguyent
Post by 16nguyent » 29 Jan 2021, 22:39
Can someone give me a good setting for this monitor, specific warzone. I want to see clear while having good frame. There are so many different settings on here. I'm not sure what to set up on my nvidia control panel setting either. I have a 2080 Ti
lostyBLUR
Post by lostyBLUR » 29 Jan 2021, 23:37
Does shadow boost increase input lag?
