Post
by Chief Blur Buster » 19 Jan 2021, 22:46
Chopper1337 wrote: ↑18 Jan 2021, 18:28
I can't post links so GitHub but my username and the repository name are as follows:
Chopper1337/OorBuster
Link:
https://github.com/Chopper1337/OORbuster
P.S. New members can't post links at first, but after a few posts, link posting capability activates. I think you now can post links seeing that you already have a few posts.
Monster
Post
by Monster » 25 Jan 2021, 07:04
I have the xl2430t model. There is a problem when it passes 165 hz. It does not work above 165 hz. Is it because gtx 550ti old video card?
connected with dvi
The bidet says out of range when I turn it on and off on every monitor, the screen comes up when you press the control button of the monitor, how can I fix it
thanks in advance
pls help
Here is why there is no color depth adjustment video card gtx 550 ti
- Ekran Görüntüsü (7).png (125.96 KiB) Viewed 10644 times
Monster
Post
by Monster » 02 Feb 2021, 17:35
I output at 177 hz with 8 bit deep dvi, how can I lower it to 6 bit depth
xl2430
appreciate if you help instant mode and but open
what other settings should i open
PureBacoN
Post
by PureBacoN » 05 Feb 2021, 06:26
Hey,
found this awesome thread and since I have a XL2411Z (2015) tried the overclock.
I couldnt get SoftMCCs working (.exe crashed after applying the higher res)
But it worked with the OOR Buster.
1920x1080@180 (without visible scanlines)
And maxed out at 210hz (220 --> Blackscreen). (It works but I can see horizontal scanlines; Which is a bummer, is there a way to fix that?)
I'm using Dual Link DVI.
210hz is not frameskipping as far as I tested it.
I would post links but this is literaly my first post.
sauceman69
Post
by sauceman69 » 05 Feb 2021, 21:47
Can Someone help me with the xl2411p.
I have tried OORbuster and im pretty sure I am doing everything wrong.
I dont know what im supposed to put in the target field, after the last quote do i put just the numbers 2000 500 250 3000 or do i do this <OOR delay 2000> <Pic delay 500> <AMA delay 250> <Wake delay 3000> ?
Im just so confused.
Can somebody show step by step method that works?
MarkBurghouwt123
Post
by MarkBurghouwt123 » 09 Feb 2021, 07:13
sauceman69 wrote: ↑05 Feb 2021, 21:47
I have it as well, I think the XL2411P doesn't work with this method
benqoced86
Post
by benqoced86 » 12 Mar 2021, 17:42
Hello from Portugal.
I have the Benq XL2411
P 144hz. I got to 200hz using a DP, GTX1070 8GB, Windows 10 and a 2nd monitor. I just followed the instructions from the 1st post starting here "The "Out Of Range" Defeat Trick" and it was straightforward.
Frame skipping test passed
CRSED online w/ 40 players passed
I hope this lives another 2 years and my wallet says thanks(for now)!
Benq XL2411P 144hz @ 200hz - 6 bit color is forced instead of 8 bit - more fps but less quality
F/W VERSION: V002-20170824
Force 6 bit color for more fps by editing CRU 1.5.1
Leonardo9795
Post
by Leonardo9795 » 14 Mar 2021, 13:00
IDK how to do whit my XL 2411P, i need a video for how to do whit oorbuster bs i m not understanding all the sequences to do. With the standard method is not working on XL2411P and as i see for there are troubles ppl for that specific monitor.
Klemern
Post
by Klemern » 18 Mar 2021, 12:32
benqoced86 wrote: ↑12 Mar 2021, 17:42
Please tell me how did you done that. I clicked the right buttons and just nothing happens. No logs on MCCS, No image on screan. XL2411P, GTX1070 and DP too
Can you make a video please? Do the same things and nothing happened.
RealNC on 21 Mar 2021, 13:27, edited 1 time in total.
Reason: Merged double post.
coolsuf
Post
by coolsuf » 23 Mar 2021, 03:38
on my XL2411p i can get a max of 165 hz but anything over works but with major artifacting (unable to see anything). is 165 the max for my monitor or can i do anything else? ive tried using lower resolution like 960p and 720p with no luck. also 1665 hz has this scanline effect which is kinda annouing. im using chopper1337's OorBuster
