ah ok so it's cool.
in response to my questions :
is it normal when I pass the Vertical Total 1350 the screen is brighter?
and at the Color Settings? because white does not really. settings you have for me?
help screen adjustment xl2720z with blur reduction on
davidd59
Re: help screen adjustment xl2720z with blur reduction on
-- Yes, it's normal for the picture to be brighter during VT1350. It is using longer strobes.davidd59 wrote:is it normal when I pass the Vertical Total 1350 the screen is brighter?
-- For colors, you can calibrate colors via your monitor while using Lagom test patterns (www.lagom.nl/lcd-test), or a calibration utility such as Windows calibration (e.g. Windows 8 Calibration), or via NVIDIA Control Panel.
MaximilianKohler
I was having this same problem, then I set it to 1320 instead of 1350. The extra brightness is there and the UFO test detects it correctly as 120hz 120fps. But the ghosting is significantly worse than when I set it to 1350. Is there really supposed to be that big of a difference between 1320 and 1350? Like it's almost hard to tell that it's not at the default.
I'm on a 290x so the pixel clock patcher should work fine, but I'm hesitant to install it because of the known issues that are listed there: http://www.monitortests.com/forum/Threa ... ck-Patcher
Also, I'm wondering what settings for horizontal and vertical total to use for 800x600 resolution ("maintain aspect ratio" would be used), and how would I force the game I play at that resolution to use the setting?
There should not be that dramatic a difference. Did you readjust the "Crosstalk" setting in Strobe Utility?MaximilianKohler wrote:But the ghosting is significantly worse than when I set it to 1350. Is there really supposed to be that big of a difference between 1320 and 1350? Like it's almost hard to tell that it's not at the default.
You can also try the 1350 tweak again, but with a smaller Horizontal Total (e.g. 2024 or 2040).
MaximilianKohler
It won't let me put the horizontal total down that low :/Chief Blur Buster wrote:There should not be that dramatic a difference. Did you readjust the "Crosstalk" setting in Strobe Utility?MaximilianKohler wrote:But the ghosting is significantly worse than when I set it to 1350. Is there really supposed to be that big of a difference between 1320 and 1350? Like it's almost hard to tell that it's not at the default.
Any idea what settings for horizontal and vertical total to use for 800x600 resolution (with "maintain aspect ratio"), and how I would force the game I play at that resolution to use the setting?
To use low horizontal totals, you need to make sure (resolution + sync pixels + front porch + back porch) is low enough. For example, 1920 horizontal resolution plus 400 horizontal front porch means you can't do horizontal total less than (1920 + 400). So to get lower horizontal totals, you need to decrease the other numbers (sync, porches) in order to fit a smaller horizontal total.
That said, not all displays can support very short horizontal totals...
As for 800x600, try adding 100 lines at a time, until it goes out of sync. e.g. Vertical Total 700, 800, 900... Also, the scanout behavior of non-native resolutions are untested, but you will know it is working when the strobe crosstalk (ghosting) becomes progressively fainter and fainter during larger and larger vertical totals.
