Is my Acer Predator XB272 malfunctioning?
Lambert
Post by Lambert » 28 Feb 2021, 10:31
Hi, recently I have bought Acer Predator XB272bmiprz because I had been looking for a new gaming monitor and found it out on one of blurbusters recommendation lists. So far it has been a fine upgrade with G-Sync and smootheness, but I don't know if I should worry or not because not everything works as I hoped and thought this would be a good place to ask.
Firstly, there seem no way to enable ULMB at 120/144hz on the monitor. Enabling it results in brief darkening of screen (as if ULMB was enabled) but suddenly after black screen appears. The Windows/game in the background works because I can hear audio so that is not software crash. In this state I cannot even access monitors OSD and all I can do is to turn ULMB off via NVidia drivers on my second monitor. The only refresh rate that does work with ULMB however is 100hz.
The second issue is that despite setting refresh rate at 240hz (+G-Sync enabled and the V-sync in game enabled), the max FPS I can get is 225. I tried turning G-Sync off, keeping refresh rate at 240hz, but still, max frames is 225. This isnt rig performance issue because I can achieve ~300 frames in the games I tested.
My GFX card is Gigabyte GeForce RTX 2070 Windforce 8GB GDDR6. I have no idea how to fix the ULMB issue, I tried using both single and dual monitor setups but nothing seem to be working. I don't even know if this is issue with my PC or monitor. How can I troubleshoot this? Thanks.
leekamon
Re: Is my Acer Predator XB272 malfunctioning?
Post by leekamon » 01 Mar 2021, 13:15
Hey there. I've been a long time user for the same monitor as yours. I decided to pull it out of the closet and get it a go again. To answer your second question, Usually when its capped at 225 on a 240hz monitor means you have NULL to set ultra. It does the capping automatically for you. However if you set NULL to ON, you can do the 237 framerate cap. Now on to your first question. I used to have back screen all the time when ULMB was set to on. The only reason was because I messed around with the vertical tweaks and made weird NON-SUPPORTED refresh rates for ULMB. Do you by a chance have ever touched CRU with monitor? You could always try to reset all the values back to default and see if 120hz/144hz works still.
Post by Chief Blur Buster » 01 Mar 2021, 17:00
Yes, ULMB doesn't support many refresh rates. Run toastX's reset-all.exe
I prefer monitors with strobe-any-Hz support (like Blur Busters Approved monitors that I am working on).
Yes, ULMB doesn't support many refresh rates. Run toastX's reset-all.exe if ULMB is a priority.
Generally, I prefer monitors with strobe-any-Hz support -- like Blur Busters Approved monitors that I am working on.
