Anyone know of any Direct Lit LED Gaming monitors?
STOPchris
Re: Anyone know of any Direct Lit LED Gaming monitors?
Post by STOPchris » 03 Mar 2021, 22:11
Chief Blur Buster wrote:
03 Mar 2021, 20:58
XL2411P is edgelit. As of now (early 2021), ALL modern gaming monitors are edgelit except for a few models like 4-figure-priced G-SYNC Ultimate.
STOPchris wrote:
27 Feb 2021, 18:53
Are you sure about this? I have the AW2721D from Alienware and it is Gsync Ultimate, but I've read it is not a full array back light.
I checked and... You're right. It has local dimming, but it's edgelight-based local dimming. Thanks for the correction. I am not frequently exposed to Dell/Alienware brand, nor work with these people (yet...).
I wish it was full array. The local dimming that the AW2721D uses works alright. However, every once in a while I will see a line of faint light going down the monitor. Basically, if there is a black image with a small white shape in the middle. During normal usage it looks fine. The main reason I don't use it is because it adds input lag.
Londan
Post by Londan » 05 Mar 2021, 08:14
Duox wrote:
03 Mar 2021, 13:32
Londan wrote:
27 Feb 2021, 20:20
I I actually have an early XL2411P and think it is direct backlit - atleast according to rtings review it is (under local dimming section). I have 0 issues with this monitor atleast.
Contacted BenQ directly through email support , Twitter , and REddit and they all said it was Edge Lit like the rest of their panels. I contacted rtings and they said they had heard this from a few users now and were going to retest. Wondering if it changed without them changing the number at some point.
I think this is what might have happened - a change of panels at some point. If not that means there is a possibility that my eyes are just sensitive to different panel types other than TN and I could potentially try a newer TN. So annoying to have to try figure this out, hopefully we get to a point some day where we understand the causes of these sorts of things so people dont have to go through this process themselves.
Duox
Post by Duox » 12 Mar 2021, 15:14
I spent 2 weeks with the GL850 and while the strain wasn't as immediate it still became unbearable within a few hours. I have returned it and am not sure what to try next. I give up on IPS , and the well reviewed Gigabyte VA monitor was just as bad. I guess I will try a basic TN panel 144hz and see if that bothers me as well . I'm fairly certain at this point its the Edge Lit backlight that is doing it though.
Londan
Post by Londan » 31 Dec 2021, 12:07
Duox wrote:
12 Mar 2021, 15:14
Sorry to bump an old thread but have you since found a solution for yourself Duox. I recently bought an old direct-lit monitor (asus pg279q) from ebay to rule this out and unfortunately my eye strain has persisted with this monitor. So now I have tried:
  • LG GL850
  • LG GL83A
  • Samsung G7
  • Omen x 27
  • MSI MAG274QRF-QD
  • Asus PG279Q
All of these give me varying levels of eye strain but my old XL2411P does not, I really want to make the jump to a decent 1440p gaming monitor (i'm actually still using the MSI MAG274QRF-QD despite the eye strain because it's that much better). I'm not sure the commonality in all of these monitors (or what's different in the XL2411P).
