BenQ XL2540K or Asus VG258QM
Re: BenQ XL2540K or Asus VG258QM
does somebody have early access ? https://www.rtings.com/monitor/reviews/ ... ng-vg258qm
sure. Don't Know if can I share it.
The monitor is 10bit with contrast of 1107 : 1 and 424 cd/m² SDR Peak Brightness.
Bad viewing angle like other TN.
Best Overdrive Setting 280Hz
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
Dark Rise / Fall Time
1.5 ms
Dark Total Response Time
4.6 ms
Dark Overshoot Error
7.8 %
Input Lag
Native Resolution
2.4 ms
Native Resolution @ 60Hz
34.7 ms
Variable Refresh Rate
2.6 ms
Variable Refresh Rate @ 60Hz
39.9 ms
10 Bit HDR
4.1 ms
Black Frame Insertion (BFI)
4.7 ms
I will receive mine tomorrow, so I can test it
Yes I do, what would u like to see?
Ty !) Input lag looks like should be higher than on mine vg279qm, it sad news.ezbill wrote: ↑25 Mar 2021, 01:55sure. Don't Know if can I share it.
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
yes, seems not that great, tomorrow I will test it. Do you want to see something in particular?sk1p wrote: ↑25 Mar 2021, 10:07Ty !) Input lag looks like should be higher than on mine vg279qm, it sad news.ezbill wrote: ↑25 Mar 2021, 01:55sure. Don't Know if can I share it.
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
Hey, could one of you post response time results for overdrive Level 4 and Level 5 please?
Main display (TV/PC monitor): LG G3 55G33LA (4K 120 Hz OLED evo)
Tested displays: LG C2 42C21LA (120 Hz OLED) • Dell S3222DGM (165 Hz VA) • ASUS VG259QM/VG279QM (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (Mineral Satin, fully loaded, size C)
Not available at the moment. The ELMB Sync seems to be much better implemented than vg259/79qm.
I see, thanks anyway
No double pulse strobe when using ELMB-Sync?
If they actually got it right with the VG258QM it will be the first monitor they released with properly functioning ELMB-Sync (not to be confused with standard ELMB since it works correctly in every single Asus monitor).
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
